It's a Bosch Exxcel. Everything seems to be working fine, the clothes come out spun, the water is drained at the end of the cycle. But if I put the clothes into some water I can see that they are still full of detergent. There is water in the drum when the rinse cycle is running. Tested the water supply to the machine by unconnecting the hose - there is a good water pressure from the mains. Checked the soap dispenser, there are no blockages, checked the pump filter - no debris. This has only recently started happening, it was ok before. Tried changing detergent and using less detergent. Happens on even small wash loads so not due to overloading and still happens if I select the option of an extra rinse cycle. There are no flashing lights to show inadequate water supply but presumably this is the cause - I can't work out where the problem is though.
Thanks.
Thanks.
