DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Tanking a cellar
This topic originated from the How to page called Rendering
Click here to return to the page called Rendering.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
  View previous topic :: View next topic
Author Message
doddy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 05, 2007 4:28 pm    Post Subject:
Tanking a cellar
Reply with quote Thanks
Is the normal render mixes suitable for tanking cellars ie: 4/1 sharp sand,cement.Do I need to add pva to the mix to make it water resistant,please help
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
FredFlintstone
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 05, 2007 7:36 pm    Post Subject:
You need a tanking kit. You paint the stuff on the wall and THEN replaster. If it's a damp proof course you're thinking of then you inject the chemical into the mortar course and then replaster, adding rendamix to the sand and cement mix.
Regards
Fred
Back to top
 Alert Moderators
doddy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 06, 2007 9:55 am    Post Subject:
The front wall in the cellar was done 'professionally'?(by a local posse) before we bought the hotel, the root of the problem was a fall pipe that was left as a soak away in front of the wall and they have not put a full concrete slab down, only concreted upto the wall which is built on a clay bed so it is holding water and causing rising damp(miss jones).Once I get the slab under the wall it should dry out, would a normal render then be suitable ?
Cheers
doddy
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
rendering cellar ceiling 2 680 Sun Jun 10, 2007 6:29 pm
Plastering cellar walls 5 760 Sat Apr 05, 2008 10:43 am
Tanking a chimney wall 6 260 Thu Sep 03, 2009 2:00 pm
tanking shower 5 320 Fri Mar 06, 2009 12:47 pm
Tanking nescessary after addition of sika 1? 3 500 Sun Jun 29, 2008 9:09 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
