Joined: 01 Jul 2007 Posts: 26 Location: United Kingdom Thanked: 0 times
Posted: Sun Jul 08, 2007 4:09 pm Post Subject:
which trap???
I'm having a nightmare with my pedestal basin. The waste pipe (copper) is about 3cm to the right of my waste from my basin. I've tried to join the two up but the basin leaks, as it sits a funny angle. I cant move the basin right any further as it is against the boxing in for my toilet cistern. The copper pipe itself, is behind some boxing in, which i have had to cut some of it away to gain access to the pipe, of which there is no give, ive tried various peices of trap to give me an extension but cant seem to get the basin square on the wall and maintain a good seal on all the traps. Would a flexi hose be of any advantage and can you cut these down. If so, how do if fit it to the existing trap and pipe. Your help would be greatly received, as im at the final stages of refitting my bathroom and at the end of my tether!!!
Posted: Sun Jul 08, 2007 9:13 pm Post Subject:
Which trap continued.
Hi. thanks for the replies. Ive posted a picture. As you can see in the picture ive connected a reducer to the copper piper which makes it look longer than it actually is. As one of the replies was to scrap the copper waste....I dont think my original explanation was spot on...as you can quite rightly see from the pic...it is impossible to simply scrap the waste, as that is the one that originally came with the house some 40 years ago. If i could attach a flexihose to it, i think that would be a simple solution, just dont know how to go about it and where to get them from. Any ideas???
Posted: Sun Jul 08, 2007 9:23 pm Post Subject:
Posted: Mon Jul 09, 2007 3:22 pm Post Subject:
which trap continued again.
HI guys thanks for your posts....are the flexihoses of the push fit variety as the two traps (s bend me thinks) are of the screw variety. can i mix and match, which would be easiest.
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Mon Jul 09, 2007 4:02 pm Post Subject:
No, one end is compression (like the one in the wall in your photo) and the other pushes into the compression side of the trap. You need a P trap or some such:
Posted: Mon Jul 09, 2007 4:09 pm Post Subject:
yeah got a P trap on the basin as shown in pic....the copper pipe is of smaller diameter though so i take it the flexihose would have to slot into an adaptor??
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
