DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
New socket from light switch
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
macewindu
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 08, 2007 5:07 pm    Post Subject:
Reply with quote Thanks
is it possible to run a new double socket from light switch. due to location of new socket I\\\'m having trouble joining up to existing socket and think only option would be to run it fromn light switch. Is this possible or big no/no. Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 08, 2007 5:15 pm    Post Subject:
No.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Jul 08, 2007 5:52 pm    Post Subject:
actualy the answer is more a case of, no, it wont work
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun Jul 08, 2007 9:19 pm    Post Subject:
not necesarily breezer.. with the more commonly used way of putting live feeds to switches nowadays it's entirely possible... depending on his wiring type..
the reason it's a HUGE no no... is that the cable and fuse supplying lighting is simply not big enough for using as a power circuit..
a double socket is capable of drawing 26A, whereas your lighting circuit probably has 1mm cable, which can take only 11A, and a 6A or 10A fuse / breaker..
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sun Jul 08, 2007 9:23 pm    Post Subject:
Thought it was 14?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Jul 08, 2007 9:33 pm    Post Subject:
i relaise the point (supply to switch then light, but if you say this he may go ahead anyway- hence no it wont work
__________________
Forum = Opinions
Back to top
 Alert Moderators
FatGit
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 08, 2007 9:37 pm    Post Subject:
Surely it depends on what he wants the power for? If it is just for a TV amp then, if he a neutral at the switch he could fit a FCU or a round pin socket and it wouldn't be unsafe??
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun Jul 08, 2007 9:43 pm    Post Subject:
ARRGGGHHHH!!!
STOP telling people it's fine to put sockets onto lighting circuits.... it's not..
even with a 3A fuse in a spur, you're then limiting the rest of the circuit to 3A on a 6A breaker..
a single socket can draw 13A.. even if you fit it with a 3A fuse in a FCU, at some point some idiot will change the fuse to a 13A so they can plug in a heater or a drill or a train set or any other multitude of items..
it's not at all hard to find a power circuit to spur off.. most houses will have a way to get cables into the loft ( via an airing cupboard etc.. )
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Socket from a light switch 14 620 Tue Mar 30, 2004 2:18 pm
Loft Light, Switch and double socket 4 440 Mon Nov 26, 2007 3:50 pm
Moving a light switch ( adding socket) 2 1740 Mon Aug 21, 2006 12:30 pm
Getting Feed to socket from light switch 11 940 Wed Aug 16, 2006 12:45 pm
Socket/light switch height? + new and old house questions 3 2120 Mon Feb 18, 2008 8:06 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
