Tom Sendall
Joined: 08 Jul 2007 Posts: 2 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Sun Jul 08, 2007 7:20 pm Post Subject: Central Heating problem |
I have a 2 year old Baxi 105e Instant. About 4 months ago I noticed the system was losing pressure, alittle at first,then alot so I kept topping it up(the pressure went down to 0, then I refilled it to 1 bar (when cold)). There was no obvious signs of a leak (no damp patches on the ground floor ceiling and I accessed the sub-floor void several times - no leaks (its a two storey house with no pipework in the roof)), so was advised it may be a faulty overflow relief valve. I have been looking into the problem for a while, and today changed the valve, but the same thing happened - rads got hot, pressure went up accordingly, ORV let water out (when pressure got to above 3 bar) then stopped letting out water. However, I lost all pressure in the boiler again - but only when the rads were on - when the boiler is set to taps only the system does not lose pressure. Where can I be losing water from? Is it the boiler or the system? All rad's are getting hot with no cold spots.
Any ideas would be most welcome.
Many thanks, Tom Sendall  |
corgiman
Joined: 25 Aug 2003 Posts: 9195 Location: Surrey, United Kingdom Thanked: 2 times
Posted: Sun Jul 08, 2007 7:27 pm Post Subject: |
do a search on expansion vessels __________________ If at first you don't succeed, remove all evidence you ever tried. |
gas4you
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Sun Jul 08, 2007 9:49 pm Post Subject: |
Check that your filling loop is fully shutting off first, then if it is do as corgi says for expansion vessel faults. __________________ Dave
DRL Gas Services |
Tom Sendall
Posted: Thu Jul 12, 2007 4:50 pm Post Subject: Yes, I now see! |
Thanks for the response, expansion vessel it is then....
Cheers for your help
Highest regards, Tom |
