DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Internal Wall Insulation
This topic originated from the How to page called Wall Insulation
Click here to return to the page called Wall Insulation.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
JBDIY
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 09, 2007 12:09 pm    Post Subject:
Reply with quote Thanks
I have just bought a timber framed house with a wooden clapboard external wall and lime plastered internal wall( the lime plaster is old and the surface needs to be done). There is currently no wall insulation.
I was thinking of putting up insulating plaster board over the lime plaster to straighten the walls and insulate the house however i am wondering if the lime plaster would be still be able to breath or otherwise be negativley affected?
I was thinking of leaving a gap between the batons and the wall but would this be sufficent?
Also what thickness of plasterboard would be sufficent?
Any help appeciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 71 times
PostPosted: Mon Jul 09, 2007 6:28 pm    Post Subject:
why not remove the original plaster, fix a vapour barrier, 60mm cellotex across the timber frame, then 12.5mm plaster boards and skim?
you could also fill the void with quilt type insulation too.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Internal wall insulation (cavity wall). Reducing U-value 3 2100 Wed Nov 21, 2007 3:20 pm
Internal wall insulation 4 380 Thu Oct 15, 2009 12:04 pm
Internal ceiling insulation query 2 880 Thu Jan 24, 2008 5:08 pm
help on internal insulation 3 1580 Fri Feb 03, 2006 10:36 am
Internal Insulation 4 1040 Mon Jan 07, 2008 4:18 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
