DIYnot
Local | Network
   DIYnot > Forums
Local | Network
High Flow Shower Waste More Than 50 Litre Per Minutes
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Barney007
from United Kingdom
PostPosted: Tue Jul 10, 2007 3:04 pm Reply with quote
Hi
I need to source a shower waste that can remove 50 litres per minute from a Bette metal shower tray, and I'm having trouble finding one. Hansgrohe do manufacture one called the Rain Drain, but it is not available until at least september this year.
If no-one knows of a waste that can do this, then I could go down the route of finding an enamelled metal shower tray that I could fit two standard 30 litres per minutes shower wastes, but I as yet haven't found such a shower tray.
Any help would be great!
Ta.
Barney
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 51 times
PostPosted: Tue Jul 10, 2007 3:24 pm Reply with quote
50 lpm?, what you fitting in there, a carwash?
Back to top
 Alert Moderators
Barney007
from United Kingdom
PostPosted: Tue Jul 10, 2007 3:27 pm Reply with quote
No, it's an uber shower system with v large overhead, handshower and bodyjets, and it's going to need to cater for the possibility that all are on at the same time.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1096 times
PostPosted: Tue Jul 10, 2007 3:34 pm Reply with quote
Have you consulted the makers of the thing for advice?
What is the output of the shower pump that supplies it, and where is it getting all this water from? Obviously not a water cylinder as it will be empty in a couple of minutes, nor a 50gall cold water cistern that will be empty in 4 minutes.
What sizes is the pipework supplying it?
Back to top
 Alert Moderators
Barney007
from United Kingdom
PostPosted: Tue Jul 10, 2007 8:03 pm Reply with quote
The DHW system is quite immense - it's not mine, it's a friends who has run dry on inspiration from his plumber.
The makers of the shower equipment - Hansgrohe Rainmaker (see Rainmaker) do have a solution but it won't be available until September at the earliest, and I need to help sort this issue out PDQ.
What is providing the water - one of those Rainmakers, a couple of handshowers and 4 bodyjets, all I have been reliably informed *may* be on at the same time, though probably not, he just want's the capacity if he needs it.
It seems like most shower wastes are rated at about 30 lpm. Definitely need 50 lpm!
Pipework to all components is 3/4 inch.
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 245 times
PostPosted: Tue Jul 10, 2007 8:20 pm Reply with quote
And, of course, you friend will be telling his water supplier that he is installing such a beast won't he (as he are required to do and so that they can install a water meter for him!)
Back to top
 Alert Moderators
doitall
from United Kingdom
Thanked: 1131 times
PostPosted: Tue Jul 10, 2007 8:25 pm Reply with quote
110mm floor drains are readily available and will laugh at 50 L/min.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2571 times
PostPosted: Tue Jul 10, 2007 9:27 pm Reply with quote
We are interested to know where this water is coming from and how its going to get heated.
Even the 500 li unventeds that DIA used to install will be emptied in 10 minutes!
If its a combi then it needs to be 120 kW output power! Probably need a 3" gas meter too.
Tony
Back to top
 Alert Moderators
simond
from United Kingdom
Thanked: 258 times
PostPosted: Wed Jul 11, 2007 7:48 am Reply with quote
50l/m is easily obtainable with an accumulator fed unvented set up. And as you say, a 4" waste is easily procured too. Don't know whether I'd be the one volunteering to drill the shower tray, though.
Back to top
 Alert Moderators
doitall
from United Kingdom
Thanked: 1131 times
PostPosted: Wed Jul 11, 2007 5:45 pm Reply with quote
Tony
I would guess the op is talking 50 L/min 30/20 hot and cold.
Don't think there's a problem getting the water, more getting rid of it icon_lol.gif [/quote]
Back to top
 Alert Moderators
Barney007
from United Kingdom
PostPosted: Wed Jul 11, 2007 6:57 pm Reply with quote
Simond - I've had a search around for one of these and cant find one anywhere. Could you point me in the right direction? Or give me a brand name I could search on?
TBH I don't know too much about the water system specification. I know that it's multiple cylinders.
Back to top
 Alert Moderators
simond
from United Kingdom
Thanked: 258 times
PostPosted: Wed Jul 11, 2007 8:01 pm Reply with quote
Barney
You need to do a search for GAH's (or our HWCH) web site on google.
Ideally you would procure what is called a DualStream, which is a packaged, warranted solution comprising the unvented cylinder and accumulator. Comes on a pallet and is available with OSO or Ariston branded cylinders.
GAH can recommend an experienced installer in your area, don't get it fitted by someone who hasn't done one before........ We've had to refit two south London installs this year where the contractor has misunderstood the concept and made some sizing mistakes.
Back to top
 Alert Moderators
Barney007
from United Kingdom
PostPosted: Wed Jul 11, 2007 8:11 pm Reply with quote
Simon
It's not the heating/storage system I need, that's being dealt with by the plumber, but thanks for the tip - I'll pass it on.
The DualStream system looks pretty impressive. They didn't appear to give a maximum flow rate though.
Yes, what I urgently need to source is the shower waste - I managed to find one at Plumbworld, however this has a max flowrate of 36 LPM. Ideally needing 51LPM from a single waste. Any thoughts?
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 1933 times
PostPosted: Wed Jul 11, 2007 8:19 pm Reply with quote
Sorry Barney can't help, but DIA can... Think he already has to...
Simon, can I drop you an email? We have a large house that I was mulling over the Break tank and Accumulator options, but think the Accs is the way 'cos of drinking water and the odd nature of the property.
Say if it's not OK...
Back to top
 Alert Moderators
simond
from United Kingdom
Thanked: 258 times
PostPosted: Wed Jul 11, 2007 8:27 pm Reply with quote
Of course, Dan, send me an email.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
170 litre Megaflo unvented cylinder for a 2 bed house?? 7 460 Wed Nov 24, 2010 8:12 am
Support in loft for 250 litre Megaflo 2 320 Tue Oct 13, 2009 12:12 pm
250 litre unvented cylinder with 13 radiators - which boiler 17 420 Tue May 17, 2011 6:23 pm
regent 10 litre water heater 4 100 Sun Mar 25, 2012 10:50 pm
is a 210 litre tank big enough? 7 140 Fri Jun 22, 2012 9:55 am
DIYnot
