DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Waterproof 2nd Level Tile Flooring
This topic originated from the How to page called Ceramic floor tiles
Click here to return to the page called Ceramic floor tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Tommy7115
from United States of America
Thanked: 0 times
PostPosted: Tue Jul 10, 2007 4:24 pm    Post Subject:
Reply with quote Thanks
I have recently purchased a small commercial building with tile on most of the second floor. The tile is over concrete slab. During the cleanup process we noticed that water was leaking through and slowly dripping onto the first floor. It is hard to determine just where the leaks are as the water slowly trickles downstairs, it takes awhile it seems. I think water just slowly seaps through either the grout or the tile itself. Is there anything I can do to waterproof the tile upstairs, aside from ripping all the tile out and adding a waterproofing material and redoing the tile. The cost for that is just too high. Any help or advice would be appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Jul 10, 2007 5:57 pm    Post Subject:
This is what insurance is for.
Back to top
 Alert Moderators
anobium
from United Kingdom
Thanked: 2 times
PostPosted: Tue Jul 10, 2007 8:11 pm    Post Subject:
Softus wrote
I don't think so, that would come under the general heading of normal maintenance.
More importantly why is he getting water leaking through a solid floor.
Floors are not designed to be waterproof.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Jul 10, 2007 8:23 pm    Post Subject:
If you're implying that the floor could leak only if wrongly maintained, or not maintained, then I agree.
However, if a substantial amount of flooring is installed, and it develops a fault, then a buildings insurance claim seems to be eminently appropriate, in the same way that a leaking roof would lead to a valid claim.
Haven't you just answered your own question?
Back to top
 Alert Moderators
Tommy7115
Thanked: 0 times
PostPosted: Tue Jul 10, 2007 10:34 pm    Post Subject:
So you're saying the blame lies in the concrete slab rather than the tile? My problem occurs slowly, with water slowly seeping through the floor. If I pour a lot of water one day, it drips downstairs the next. No other solutions, other than redoing the whole thing?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Jul 10, 2007 10:38 pm    Post Subject:
Er, no, because no slab is waterproof/impervious.
Is there any sign of deteriorated grout?
What's the 2nd floor room used for? Do you have to pour a lot of water on it?
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Tue Jul 10, 2007 11:08 pm    Post Subject:
im lost icon_eek.gif what is leaking or where is the water coming from? bit confused but sounds like your water the floor every day icon_lol.gif source where the leak is or stop watering the floor. It wont grow you know icon_exclaim.gif
Back to top
 Alert Moderators
bananaspark
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 11, 2007 2:09 am    Post Subject:
tap all the tiles with a bit of wood, to see if any 'sound' different, hollow ones should be relaid at least.
grind all the grout out with an appropriate tool, clean, and apply new grout. seal grout lines when dry, let that dry, then dump your bucket of water on the new floor.
wait for leak, if none then congratulations, otherwise a wasted weekend.
b/
Back to top
 Alert Moderators
Tommy7115
Thanked: 0 times
PostPosted: Wed Jul 11, 2007 3:25 am    Post Subject:
Its actually an upstairs kitchen/bar area. We were cleaning it when we got the property and of course poured a bit of water on the tile. It started leaking a little while later onto the first floor. The grout actually looks fine. It doesn't take that much water before it'll start leaking. There are several spots where it leaks, but I can't really pinpoint the exact place. Plus, its hard to tell as it seems to take a little while for the water to travel through the tile/grout/concrete slab, before it starts dripping below.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jul 11, 2007 9:31 am    Post Subject:
I can't think of any circumstances where I'd just pour water onto the floor, unless it were in a tanked bathroom. Can you not just clean it in the normal way? icon_confused.gif
Well clearly it isn't fine, unless you're pouring so much water that it's reaching the edge of the tiled area and escaping that way. Has the floor been sealed to the wall (or whatever it buts against)?
You'll never find out where the leak is by looking in the room below, because the water will travel laterally until it finds a way through.
If it were mine then I'd stop doing the pouring thing.
Back to top
 Alert Moderators
anobium
from United Kingdom
Thanked: 2 times
PostPosted: Wed Jul 11, 2007 4:36 pm    Post Subject:
Softus wrote
Not strictly true, your building insurance only covers you for storm, fire or flood damage.
A leaking roof could be just normal wear and tear, ie corroded nails holding the slates, worn lead flashing etc.
If however a water pipe within the floor had been punctured then Tommy 7115 would be covered by his insurance.
Just because he is daft enough to pour buckets of water on the floor I think the insurance co will politely tell him to take a running jump.
The only floors designed to hold water are those in a wet room.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jul 11, 2007 4:41 pm    Post Subject:
You're right. I was wrong.
Quite so.
Back to top
 Alert Moderators
Tommy7115
Thanked: 0 times
PostPosted: Wed Jul 11, 2007 7:04 pm    Post Subject:
Well, if you saw how much grime and oil was on the floor after all the furniture/equipment was removed, you'd see why a lot of water was used to clean the place. I do believe, like you guys say, the water is finding its way at the edges of the tile, where it meets the walls. Perhaps some kind of cement sealant could be used in those areas? Any suggestions?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jul 11, 2007 8:58 pm    Post Subject:
Given what you/we now know, my advice to you is to steam off the grime.
This product is probably just the job, for a modest outlay, but if you're hard up I don't see why you couldn't use a wallpaper steamer.
Quote:
There I do believe, like you guys say, the water is finding its way at the edges of the tile, where it meets the walls. Perhaps some kind of cement sealant could be used in those areas? Any suggestions?
I wouldn't use anything cement based, I'd use good old Dow Corning 785 silicone sealant.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
how to waterproof an oak floor in bathroom? 2 240 Fri Sep 11, 2009 3:59 pm
Laminate Floor For Kitchen - Waterproof Membrane Needed? 17 2020 Mon Jan 26, 2009 10:10 pm
waterproof grout for bathroom floor 2 700 Tue Mar 08, 2005 1:02 pm
Paint and Waterproof wooden floor in bathroom? 2 700 Fri Feb 08, 2008 9:14 am
WATERPROOF PRIMER NEEDED ? 14 780 Sun Apr 29, 2007 9:14 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
