DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Luxury Bath/Shower Mixer Standpipe
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
benthecowman
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 11, 2007 9:20 am    Post Subject:
Reply with quote Thanks
I have the task of fitting this bath/shower mixer standpipe to sit adjacent to a freestanding bath. I am unsure about how to connect the flexible tap connectors which seem to want to connect to a 15mm compression isolation valve type fitting. Is this what I should be connecting to? It concerns me too that the connections are going to be beneath the floorboards due to the nature of the standpipes design thereby making the access to them particularly difficult once the bath is in place.. I'd appreciate some pointers if I'm approaching this job from the wrong angle! A link to the mixer in question is http://www.victoriaplumb.com/Bath_Shower_Mixer_Standpipe_1a.html
Thanks for anyones help in advance.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jul 11, 2007 10:22 am    Post Subject:
Re: Luxury Bath/Shower Mixer Standpipe
I'd say so, yes. However, your description isn't very precise - do the supply ends of the flexible hoses look like this (upper right end)?
If the bath supplies are 'tank-fed', then the flexibles and the 15mm connections are going to be quite restrictive, but the only way to improve that would be to reduce all other constrictions in the services.
You need to place the valves somewhere that can be reached without removing the bath. For example, via a removable panel in the floor. Extend the pipework from wherever it currently terminates to a different position, far enough away from the bath and the standpipe. Plastic pipe can be ideal if you have to drill through joists as you can easily route it through.
Back to top
 Alert Moderators
benthecowman
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 11, 2007 10:41 am    Post Subject:
Thanks for your response and sorry for the vagueness. Got loads on my plate!
I'm pretty sure the end of the braided connector is as in the photo. I would have expected it to have been a compression fitting but its more like a bsp type (i think?) that seems to fit onto the isolation valve size fitting.
I will certainly put the isolation valves somewhere that can be easily accessed but the flexi tails from the taps still need to be connected to the pipework beneath the floorboards below the standpipe so what type of connection should I be using?
Thanks again for your help.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jul 11, 2007 11:00 am    Post Subject:
Almost certainly it's a 1/2" BSP female thread (but it could be 3/4"), in which case it will fit onto any 1/2" BSP male threaded fitting, e.g. a compression-ended isolating valve.
As per above, but if you want to put the valves somewhere else then you could use a compression coupling and take the nut and olive off one end of it.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Standpipe Bath Filler - pipe connections don't fit! 7 560 Thu Feb 16, 2006 5:01 pm
Fitting second standpipe? 3 160 Fri Jun 12, 2009 10:48 am
Standpipe Height 41 1560 Wed Jan 31, 2007 2:59 pm
how High the standpipe for dishwasher drainage 7 440 Thu Feb 02, 2006 6:19 pm
Washing Machine Standpipe Overflowing 13 260 Thu Sep 03, 2009 8:15 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
