worcester combi water starts hot but goes cold
28 Nov 2005
London
Hi: Boiler fires up and the water coming from the tap starts off hot but quickly gets very cold.
Any suggestions for what I could try ?
Cheers
Rednight
I suspect this is a permanent pilot four pipe boiler.
And the DHW flow switch may have failed ( black plastic on left ) if its the model I suspect.
Could also be a wide range of other faults whatever the model.
Thats part of the fun of fixing boilers. Whatever it sounds like being failed there is sometimes an unexpected surprise!
Tony
can i make a wild guess without knowing the boiler model too???
erm....let me think....the fan! :LOL:
Depends on the model! Few use the Gianoni any more.
The four pipe HEs have a high heat content on a PP boiler and will give 2-5 litres of hot water from the latent heat stored.
The models with a secondary HE will give much less and thats not usually even enough to be noticed by the user.
So I am guessing its the PP four pipe model. Was that the 24i ?
Tony
Thanks, everyone. Its the 24I RSF model. Its not the fan, the pressure is OK (around 1 bar) and it seems as though it may be the pressure switch.
Is this easy to change ?
Rednight
