Joined: 12 Jul 2007 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Thu Jul 12, 2007 7:28 pm Post Subject:
Elastilon + underfloor heating
Has anyone used Elastilon to fix a solid wooden floor onto concrete (30yrs old)? I intend installing underfloor heating and wondered whether anyone has used the cable or matt type with Elastilon?
I was thinking of laying some DPM then heating matt, then Elastilon and wooden floor.
Any comments please
thanks
Dennis
Joined: 14 Nov 2004 Posts: 6348 Location: Kent, United Kingdom Thanked: 29 times
Posted: Fri Jul 13, 2007 7:51 am Post Subject:
See the Elastilon website for more details (wood flooring and heating page). Make sure you click on the English flag otherwise you're back here asking for Dutch translations
Personally no experience with the product.
__________________ You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Joined: 30 Jan 2007 Posts: 1650 Location: West Midlands, United Kingdom Thanked: 5 times
Posted: Fri Jul 13, 2007 4:28 pm Post Subject:
yes it can be used. But you need a good reliable heating system. You cant just turn the heat of either. When certain types of flooring including wooden flooring are installed you need to maintain the heat correct or problems can be caused.
Posted: Sat Jul 21, 2007 7:37 pm Post Subject:
Solid oak on concrete
thanks for the replies.
I have decided against the Elastilon and the heating.
However, I've had two guys around for quotes and have heard different stories.
120-130 mm prefinished solid oak:
One wants to glue the T&G and float onto DPM
The other wants to glue to concrete floor without glueing T&G.
Is this just preference of the tradesman or is there a recommended laying method?
really don't know whether I'm coming or going?
Dennis
Posted: Sat Jul 21, 2007 9:57 pm Post Subject:
Both can be right. Depends on who makes the flooring tho. There are very few manufactories who say to float a solid wood floor in the u.k., america, germany. ( Not familiar with other countrys fitting technic) But there are a couple of manufacturers that are now saying you can lay onto elastilon ( which is floating method) I would always glue the floor myself or use elastilon. Elastilon is a quicker, cheaper and much easier to fit method. I must say im not over convinced with how good the elastilon is yet tho. Have a few test cells set up doing different tests on the stuff at the moment and all seems o.k at present but will be another month until i can say i really recommend the stuff or not.!
Joined: 17 Aug 2007 Posts: 4 Location: Lincolnshire, United Kingdom Thanked: 0 times
Posted: Fri Aug 17, 2007 1:34 pm Post Subject:
Quote:
mattysupra Have a few test cells set up doing different tests on the stuff at the moment and all seems o.k at present but will be another month until i can say i really recommend the stuff or not.!
4 weeks tomorrow (not quite a month, but I am impatient).
Joined: 18 Nov 2007 Posts: 1 Location: Ireland Thanked: 0 times
Posted: Sun Nov 18, 2007 10:15 am Post Subject:
Elastilon + UF Heating
Can Elastilon be used with Solid Bamboo Flooring & UF heating? If yes are we supposed to use a membrane under elastilon & what kind of membrane we use.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
