dsingh
Joined: 13 Jul 2007 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Fri Jul 13, 2007 11:17 pm Post Subject: dual control switch for bathroom |
I need to find out a dual control switch for
switching on fan with first pull and fan plus light to be switched on with second pull. with third pull both fan plus light should go off. could any one please help me to locate the supplier or suggest alternative connection. thanks. |
GaryMo
Joined: 03 Jul 2007 Posts: 2757 Location: Manchester, United Kingdom Thanked: 19 times
Posted: Sat Jul 14, 2007 8:54 am Post Subject: |
This isn't a sweeping fan / light is it? (hope not!).
Is it a 240v fan? Which zone will it be fitted in?
If it's a recessed ceiling fan with integral 12v light then why can't you have the light coming on with the rest of the lighting and the fan being triggered by the lighting with override after the lights turn off assuming the fan has a built in timer?
Don't forget to install an isolator for the fan outside of your bathroom. |
ColJack
Joined: 16 Feb 2007 Posts: 7599 Location: West Midlands, United Kingdom Thanked: 129 times
Posted: Sun Jul 15, 2007 2:26 pm Post Subject: |
making it rediculously complicated there.. just put in a normal light switch, and have the fan PIR controlled.. no need to turn it on, it comes on when you enter the room and off after you leave.. ( should use a timer'd fan though. ) |
