DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bubbling noise
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Zanderama
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 14, 2007 9:18 pm    Post Subject:
Bubbling noise
Reply with quote Thanks
Hi, I have a potterton supremer boiler and a gledhill boilermate 2. It seems to occaisonally make a gurgling/bubbling noise. It goes when I either turn the thermostat up to winter setting then back down again or when i run the hot water tap for a while. It seems like it's overheating the water or something. I resently had the circuit board changed on the potterton and it worked fine at first but now this. Any ideas?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Sat Jul 14, 2007 10:22 pm    Post Subject:
pure guess work from the little info you have given, but a very common fault with the boilermate is low water level in the cylinder caused by a blocked cold feed pipe.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Jul 15, 2007 11:23 am    Post Subject:
Cold feed pipe on this is a ridiculous design, just waiting to get blocked. You may have to back fill the system to cure it.
If it is blocked then you boilermate will be acting as a huge crud store for the entire heating system as well as a thermal store icon_eek.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Central heating - bubbling noise from loft 9 460 Fri Feb 08, 2008 4:28 pm
Bubbling noise in house when Boiler comes on at 7:00AM 12 320 Mon Feb 02, 2009 1:34 pm
Direct cold water feed tank overfull and bubbling noise 2 240 Fri Jan 02, 2009 3:54 pm
bubbling and banging noise from back boiler 8 1020 Sun Oct 12, 2003 6:38 pm
bath plughole gurgling and bubbling when toilet flushes 4 340 Fri Jul 04, 2008 9:39 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
