DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Vokera Excell 80SP
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
cra123
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 14, 2007 10:28 pm    Post Subject:
Vokera Excell 80SP
Reply with quote Thanks
I have a Vokera Excell 80SP the pilot light is on however it is not firing up for either Hot water or Heating I have taken the front cover off and there is a ( can only descibe a humming noise) that has replaced the normal running sound of the heater before . If i press on the internal metal cover the noise defiates a little and then returns back to humming noise seems like a vibration defiation in its sound, has anyone any ideas on how i can rectify thankyou.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
rob884
from United Kingdom
Thanked: 2 times
PostPosted: Sat Jul 14, 2007 10:30 pm    Post Subject:
when you say front cover do you mean the white case or the cover to the burner chamber?
Its most likely the fan seized, it should be going at slow rate all the time?
Back to top
 Alert Moderators
cra123
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 14, 2007 10:39 pm    Post Subject:
only taken the white front cover off. The humming is coming from within the metal case housing the burner unit and it seems to be coming from the top but it is not running as it used to as i say just humming. I have turned the boiler off as I was a little concerned of the noise.I presume it will require an engineer to repair what is a estimated cost for the repair ( if you have any ideas ! ) thanks for your quick response very impressive!!!!
Back to top
 Alert Moderators
rob884
from United Kingdom
Thanked: 2 times
PostPosted: Sat Jul 14, 2007 10:45 pm    Post Subject:
Sounds very much like the fan yes.
Cost of part is maybe £100 plus fitting which doesnt take too long.
As long as the rest of the boiler is in good condition then its worth repairing!
And it would be wise to get a corgi man to carry out the work
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Sat Jul 14, 2007 10:46 pm    Post Subject:
in London we charge a fixed price diagnostic charge of £84 plus the cost of parts but that includes a service.
The Vokera parts are a little more reasonable and I think the fan is a lot less than the £100 most boiler fans cost.
Since its part of the gas train it should only be fitted by a CORGI but a very competent DIYer could probably manage.
It could probably be given a new lease of life with a little motor oil for a few days up to a few months. But DONT use WD40 as thats inflamable!
Tony
Back to top
 Alert Moderators
cra123
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 14, 2007 11:28 pm    Post Subject:
Thanks for the replies appreciated !! by the way how old is the Vokera excell 80SP ? as it was already installed when i moved into the house ( just for my info ) and when should you consider replacing a boiler is there a normal period when a boiler should be replaced.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Sat Jul 14, 2007 11:39 pm    Post Subject:
Your boiler was in current production about 1994-7.
They are expected to have a life of at least 10-12 years.
Generally I suggest that they are only replaced when they have started to be unreliable. Thats usually when they are fittted to a dirty system.
A generally reliable boiler like yours will have a diverter valve failure every 2-3 year which we fix for £106. I advise that they are well worth keeping for another three years at least.
A failed fan is very unusual! It may well result from disconnecting power while the pilot is alight as that over heats them.
Tony
Back to top
 Alert Moderators
weareleeds
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 15, 2007 9:41 am    Post Subject:
ile theA failed fan is very unusual! It may well result from disconnecting power wh pilot is alight as that over heats them.
Tony
Back to top
 Alert Moderators
weareleeds
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 15, 2007 9:44 am    Post Subject:
Oops made a buggar of that Will i agree with tony that fan failed but disagree that it is unusual. I carry one on my stock & generally change one every 2 weeks or so. But that may be because we have a lot of vokeras thup north with our cloth caps & whippets
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 18 times
PostPosted: Sun Jul 15, 2007 9:59 am    Post Subject:
This make is a favourite of mine. What with reasonably priced parts and good build quailty (not the recent models), if this boiler is serviced regularly, it will look after your heat needs for many years.
I have clients with Turbos which are over 20 years old, and still chugging away.
My advice? Keep boiler changers at arms length and have the boiler serviced properly (not 15 minute 'look see').
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Jul 15, 2007 10:56 am    Post Subject:
Retail at parts center is £91 + VAT for the fan.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vokera excell 80SP 3 381 Sun Nov 26, 2006 8:01 pm
vokera excell 80sp problem 12 780 Mon Aug 11, 2008 9:42 am
vokera Excell 80sp d 2 141 Mon Aug 18, 2008 7:26 pm
Vokera excell 80sp 6 520 Tue Aug 19, 2008 4:49 pm
vokera excell 80sp. Optional vessel kit. 4 160 Thu Sep 04, 2008 6:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
