webs
Joined: 15 Jul 2007 Posts: 12 Location: United Kingdom Thanked: 0 times
Posted: Sun Jul 15, 2007 9:21 pm Post Subject: soil pipe drainage |
im moving our washer to a utiility room.and would please like to know can my machine drain to the base of a soil pipe.im a bit concerned that \\\"stuff\\\" could come back up the stand pipe and up the outlet hose. Any advice would be appreciated |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sun Jul 15, 2007 9:39 pm Post Subject: |
no because the soil pipe runs to an inspection cover, dot directly to the sewer (unless it gets blocked) __________________ Do you like music Mr Finch?
Forum = Opinions |
bernardgreen
Joined: 03 Nov 2006 Posts: 3610 Location: Bedfordshire, United Kingdom Thanked: 22 times
Posted: Mon Jul 16, 2007 5:52 am Post Subject: |
Use a sink or wash basin cannection to the soil pipe as if you were adding a sink waste to it. This will provide a U bend which will stop fumes coming out to the washer. It ia advisable to heve a vent where the washer hose joins the waste pipe to prevent the water in the U bend being syphoned out. Vertical length of waste pipe with the hose feeding into but not sealed to this vertical
Take note of the local regulations ( building control officer a the local council can help ) and how the fit the connection to the soil pipe |
webs
Posted: Fri Jul 27, 2007 9:04 pm Post Subject: Re: soil pipe drainage |
Thanks guys for your advice you,ve set my mind at ease .Will get cracking on with it |
