DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fan Speed Control Unit
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
AlbertR
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 16, 2007 11:00 am    Post Subject:
Reply with quote Thanks
I want to install a fan speed control unit into a timed fan in order to quieten it down a touch.
The switch I have has a knob similar to a dimmer switch and at the back there are 2 terminals.
Can anyone tell which part of the circuit the control is wired to.
Thanks in anticipation
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Mon Jul 16, 2007 11:37 am    Post Subject:
it will have to go between the timer and the fan, since if you put it before the timer it will lower the voltage to it and sto it working..
Back to top
 Alert Moderators
AlbertR
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 16, 2007 12:29 pm    Post Subject:
Ah, that seems to make sense. Thanks.
The fan is a wall mounted Addvent AVX150TA.
The timer is on the circuit board. So this would involve wiring from the circuit board outlet to the fan motor.
I was thinking it would just be a case of stepping down the voltage of the permanent live but if that feeds the timer then that is why the thing won't work when I try this.
So I'm stuck with things as they are?
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Mon Jul 16, 2007 1:55 pm    Post Subject:
buy a quieter running fan? a new one often runs quieter than one a few years old as the bearings wear..
Back to top
 Alert Moderators
AlbertR
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 16, 2007 2:54 pm    Post Subject:
Yep, I'll just do that. (The fan is about ten years old I suppose!)
Many thanks for your help.
Back to top
 Alert Moderators
AlbertR
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 12, 2007 5:01 pm    Post Subject:
So back to this...
The variable Fan Control Switch has 2 terminals marked L1 and C, I take it that is for Live 1 and Common (there is a L2 but that has had its terminal removed).
How should this switch be wired?
Cheers for any help.
Oh, and what is the difference between a dimmer switch and a fan control (the fan control does say on it "For Fans Only")
Albert
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Aug 12, 2007 7:46 pm    Post Subject:
But last year you said
and as you were also told
it does not matter which way round.
however it may be that your fan is not able to be speed controlled so you may have to get a new quiter one anyway, and if you can slow it down, it will not work as well as it did since it is running slower
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Mon Aug 13, 2007 12:04 pm    Post Subject:
Back to top
 Alert Moderators
CallEdsFirst
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 13, 2007 3:44 pm    Post Subject:
So anyway, ignoring the advice and forgetting what I said I was going to do......... icon_lol.gif icon_lol.gif icon_lol.gif icon_lol.gif icon_lol.gif
Addvent, not that I would ever knock CEF's fine in-house brands, can be improved upon with something from Vent Axia/Xpelair, but definitely not anything from a skip, allegedly. icon_wink.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Fan Speed Control/Light Dimmer 12 1860 Wed Feb 13, 2008 4:31 pm
two speed switch 25 960 Wed Apr 30, 2008 7:34 pm
Fan Speed Controller 7 500 Fri Mar 24, 2006 6:24 pm
cooker control unit 6 160 Fri Jan 30, 2009 5:54 pm
Position of Control Unit 2 460 Sat Nov 05, 2005 5:35 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
