Joined: 16 Jul 2007 Posts: 14 Location: United Kingdom Thanked: 0 times
Posted: Mon Jul 16, 2007 1:10 pm Post Subject:
SMEG dishwasher freezes
we have a smeg dishwasher ( DF612SE) or atleast very similar in apearence to this one.
trouble im getting with it now is you put a wash cycle on and for aprox 5 mins it does what it should then stops. it just puts on 2 or some times 3 of the panel lights. if i open the door n restart it it will again do the same thing 5 mins later ?????
Posted: Tue Jul 17, 2007 8:33 am Post Subject:
hi mate,
thanks for replying.
the lights that come on from the left are the 1st two lights, so if the far left was called no. 1 then no. 1 and no.2 come on when the fault shows itself ..
Joined: 02 Apr 2006 Posts: 1896 Location: United Kingdom Thanked: 4 times
Posted: Tue Jul 17, 2007 3:17 pm Post Subject:
Error code 3. Not heating.
Check the thermostat and the heater.
Both should be under the dishwasher. Some have a thermostat with a red button to reset it.
Posted: Tue Jul 17, 2007 4:17 pm Post Subject:
hi again mate.
ive cured it now as i found another forum and some one had a similar problem so i basicly gave it a damn good clean with sucking up water and muck with an aquavac through the sprinkler outlets ect and now its running fine again.
Posted: Fri Jul 20, 2007 8:51 pm Post Subject:
still got the problem
the old problem is still there but i knowticed the folowing if you can help more ??
the cycle starts but it gets to the main wash and no water is going through the machine but i can hear water going out the waiste pipe so the dishwasher isnt getting any water inside to wash any thing.
the 2 lights on left come on after a while too .
any one know what i need to prepare look for tomorow when i start to repare ect ???
Posted: Fri Aug 17, 2007 8:09 pm Post Subject:
hi.
yer i gave it a danm good aqua vac sucking through any pipe or inlet n outlet that i could find including the waist pipe.
it worked for a few more washes then started it again so i took the right panel off and there is a plastic panel that chanels the water all around and i aquavaced that too , since then the problem never returned..
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
