Joined: 17 Jul 2007 Posts: 4 Location: Staffordshire, United Kingdom Thanked: 0 times
Posted: Tue Jul 17, 2007 10:49 pm Post Subject:
3 gang 2 way switch
hi im trying to replace my wall switch in the hall all i can tell you is the switch powers a light outside a hall light and a stair light there is another switch upstairs which turns the light of but its the 3 way i want to replace there is 6 red wires 2 yellow and one blue and the back of the new switch as com l1 l2 ect could you please tell me which wires go where thanks ps im a bit in the dark
Joined: 27 Jul 2006 Posts: 4932 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Tue Jul 17, 2007 10:55 pm Post Subject:
OK, easy question first.
Before removing the old switch, did you make a note of which wires went to which terminal. A photo would be good. If you did then its easy to advise you.
If you didnt then we've got a lot of work ahead of us!
PS, I like that "a bit in the dark". A deliberate pun, I guess
__________________ TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Joined: 16 Feb 2007 Posts: 7599 Location: West Midlands, United Kingdom Thanked: 129 times
Posted: Wed Jul 18, 2007 8:02 pm Post Subject:
do us a favour and take the upstairs light switch off and tell us what wires are in there.. my guess is that there is a red, yellow and blue... and nothing else...
you're missing a blue by the sounds of it too...
you'll have 2 twin reds, and 2 3Core and earth cables..
the 2 twin reds are 2 switch cables for the outside and hall light, and the 3 core with the blue cut out is the switch wire for the stairs light..
one red of each twin red goes to Com of 2 switches ( ie 1 red to 1 com, 1 red to other.. ), with the other red going to the L1 of the corresponding switch..
this sorts the outside and hall light, with the only problem being switch placement ( might not be on the "right" switch as before.. ), just swap them round if not "right"..
now the 2 3Core and earths.. the one with all 3 wires should go...
Red - L1
Yellow - L2
Blue - Com..
with the red and yellow from the other 3Core and Earth going to the terminals with the same coloured wire in them.. ( please check what wires go where on the upstairs switch and correct this order as needed ).
of course, without photo's or actually being there this is only a best guess, it's very hard to diagnose from words alone..
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
