DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Chimney Hood Distance
This topic originated from the How to page called Installing a cooker hood
Click here to return to the page called Installing a cooker hood.
  View previous topic :: View next topic
Author Message
gordsky
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 19, 2007 11:07 am    Post Subject:
Reply with quote Thanks
Am in the process of installing a chimney hood into my new kitchen and was wondering if anyone knows of a maximum distance it should be above the gas hob to work effectively. I'm aware there is a minimum distance but being quite tall I'd like to mount it higher up so as to avoid smacking my head every time I use it as it protrudes 490mm outwards from the wall. Was thinking around 850 - 900mm above the hob.
Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Thu Jul 19, 2007 11:52 am    Post Subject:
There is a min distance over gas hobs but dunno what that is.
Edit: looky here. It says its specified on the hob instructions and your CORGI fitter will make sure it complies.....
http://www.ksa.co.uk/kitchens/faqs_kitchens.asp#clearances
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 2 times
PostPosted: Thu Jul 19, 2007 1:26 pm    Post Subject:
If you make it 1 or 1.1m that's going to make it roughly 1800mm (6ft) off the ground. Should be high enough for most people to keep clear and still work ok icon_smile.gif
See how it works in with the piece to the ceiling. I try to avoid cutting that if possible.
Back to top
 Alert Moderators
ch427
from United Kingdom
Thanked: 3 times
PostPosted: Thu Jul 19, 2007 4:57 pm    Post Subject:
i think the distance is a minium of 750mm from the surface
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 2 times
PostPosted: Thu Jul 19, 2007 5:38 pm    Post Subject:
icon_rolleyes.gif Yes but the OP is wondering if there is a maximum distance
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Thu Jul 19, 2007 7:06 pm    Post Subject:
With no manufacturers instructions it is 760mm above a standard hob to any combustible surface.
If the hood manufacturer or extractor manufacturer allows it it can often be dropped to 650mm.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 2 times
PostPosted: Thu Jul 19, 2007 8:03 pm    Post Subject:
icon_rolleyes.gif icon_confused.gif I give up
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Thu Jul 19, 2007 8:49 pm    Post Subject:
Never heard of a maximum distance
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Thu Jul 19, 2007 10:46 pm    Post Subject:
He could mount it on the ceiling if he wants to!
__________________
TTC
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
No earth on Chimney hood cable 2 560 Thu Oct 12, 2006 9:01 am
Cooker Chimney Hood ~ extractor 2 920 Fri Nov 24, 2006 10:16 am
Chimney cooker hood fitted but sticky plastic left on. HELP! 4 640 Sat Nov 25, 2006 4:50 pm
Fitting a Chimney Cooker Hood - What Electrics Required?? 3 1640 Mon May 19, 2008 6:45 pm
Cooker hood/chimney wiring 6 1520 Wed Jun 13, 2007 12:43 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
