DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
FUSE KEEPS BLOWN ON MY BAXI 80 /105 COMBI
This topic originated from the Wiki page called Heating controls
Click here to return to the page called Heating controls.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
billyo
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 20, 2007 3:24 pm    Post Subject:
Reply with quote Thanks
HI/GUYS NEED ADVICE I AM NOT A PLUMBER,BUT DONT WANT TO GET RIPPED OFF,GOT A BAXI 80/105 COMBI EVERY TIME YOU CALL FOR HOT WATER 2 AMP INTERAL FUSE GOSE BANG, BOILER WONT RUN WHEN YOU PUT IT TO HOT WATER AND RADIATORS , CANT GET A PLUMER FOR THREE DAYS
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
weareleeds
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 20, 2007 3:46 pm    Post Subject:
Probably pump blowing fuses try disconnecting live to pump & see if it carries on blowing fuses
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Fri Jul 20, 2007 3:51 pm    Post Subject:
Turned the wall thermostat up?
If boiler then goes ok, look for water in HW microswitch. Don't know if that would blow a fuse though.
Turn power off, stick your head in and sniff - usually stinks of burning.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Fri Jul 20, 2007 5:23 pm    Post Subject:
Re: FUSE KEEPS BLOWN ON MY BAXI 80 /105 COMBI
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
billyo
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 21, 2007 2:52 pm    Post Subject:
blown fuse 105 ebaxi
hi, gas4you,
did as you said and took live wire of pump, this has stopped the fuse blown, panel ligths up green on water side when tap is running also red light at 60d, telling you pump has a fault .but if you put swicth on radiator and waterside just red ligth comes saying pump fualt, what next my knowledgeable friend.
best regards billyo
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sat Jul 21, 2007 3:02 pm    Post Subject:
Sounds like pump is shorting out as Weareleeds suggested.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
billyo
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 21, 2007 3:44 pm    Post Subject:
weareleeds and gas4you,
thanks guys for your anwers, if pump is cause of fuse blown,as looks likely what can i do to fix it. can pump be repaired or do i bin it, would rather fix it if poss.
best regards
billyo
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 21, 2007 3:53 pm    Post Subject:
Replace with equivalvent model.
__________________
Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man
Back to top
 Alert Moderators
clf-gas
from United Kingdom
Thanked: 25 times
PostPosted: Sat Jul 21, 2007 3:57 pm    Post Subject:
Get yourself down to the big shed and buy a replace ment pump.
Close valves either side of pump, issolate electric, place towel around the floor and remove old pump, only a bit of water.
remove wires from old and wire new as per, fit new to existing pipework and open valves, now turn electric back on on try boiler.
Well done chief the misses gets a bath you both put on the glad rags and paint the town red, she`s now got a new and pleased hubby icon_wink.gif
__________________
STUPID = Smart Talented Useful Person In Demand
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Sat Jul 21, 2007 4:20 pm    Post Subject:
As your boiler is a 105e ANY pump will not do . What you need if it is the pump causing the fault is a Grundfos 15/60 pump and just change the head of pump as the body is special to that boiler. And you will not find valves either side either as clf-gas said. You turn off boiler isolating valves
Back to top
 Alert Moderators
clf-gas
from United Kingdom
Thanked: 25 times
PostPosted: Sat Jul 21, 2007 4:37 pm    Post Subject:
Your right namsag,,,, I did`nt read the OP`s post properly. Was red misting at the time icon_mad.gif
__________________
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Sat Jul 21, 2007 4:45 pm    Post Subject:
Back to top
 Alert Moderators
billyo
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 22, 2007 4:04 pm    Post Subject:
Nam-sag
thank you, i will be down plum-centre on monday.
clf-gas calm down and keep taking the tablets
every body who had an input to my problem slover a big thank you to you all, hope i can help you some time,
best regards billyo
Back to top
 Alert Moderators
billyo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 23, 2007 2:28 pm    Post Subject:
namsag be -aware just been took for a mug down our local plumbcenter in barrow in furness when in and bough 15/60 pump as you suggestet got it home and it is a completely differant unit one on my boiler is a 15/60 TF95 one he sold me is a 15/60 130 with a swicth on it mine is 3 bar this one is 10 bar, so took it back to man at PLUMCENTER THATS PLUMCENTER, AND NASTY MAN WOULD NOT TAKE IT BACK AS HE SAID I TOOK IT OUT OF ITS BOX,i said well who an i suppose to test it he said he had heard it all before and would kindly leave his PLUMCENTER i presume he would not like me to tell other people that if you buy and then open the box you cant excheange goods so all you guys be aware of opening goods from PLUMCENTER. BILLYO HAS BEEN RIPPED OFF
Back to top
 Alert Moderators
billyo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 23, 2007 2:45 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Glow worm Ultimate 40FF boiler fuse F2 blown 7 2040 Thu Apr 05, 2007 9:08 pm
Fuse blown on a Modena 80e Boiler. 2 480 Tue Oct 10, 2006 7:46 am
Blown 3amp Fuse on Glow Worm Space Saver 10 1440 Mon Oct 08, 2007 9:42 am
vaillant turbomax 824... blown fuse? 3 280 Mon Jan 28, 2008 1:08 pm
Worcester - 24CDI - Blown fuse ?? Any advice appreciated! 3 1160 Mon Aug 07, 2006 7:14 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
