DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Problem replacing light switch
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
Chez
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 21, 2007 7:35 pm    Post Subject:
Reply with quote Thanks
Hi, hope someone can help. I have just tried to replace a 1 way switch with a 2 way dimmer switch despite there only being 1 switch assigned to the light (hope that makes sense). I connected the cables up (black to \\\"C\\\" & red to \\\"L1\\\") and left the switch hanging. I switched the mains back on and tested it and it worked perfectly. I then switched off at the mains again and screwed the face plate back into position. I then switched the mains back on, this time though when I turned the switch on there was a pop. What I want to know is why would it work fine before I replaced the face plate and what kind of damage could I have done. All other lights in the house are still working.
Hope somebody can help!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sat Jul 21, 2007 7:39 pm    Post Subject:
you've trapped a cable when putting the faceplate on, or one has come out of a screw terminal because you didn't tighten it correctly..
possibly the switch wire since the other lights still work so you havent blown the fuse but may well have knackered the dimmer...
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 0 times
Where did the pop come from? CU, dimmer or the light fitting?
Did the fuse/MCB/RCD blow?
A likely cause is that you trapped a cable between the fixing lugs on the backbox and the socket front - this may have damaged the insulation and caused a short.
Back to top
 Alert Moderators
Chez
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 21, 2007 7:46 pm    Post Subject:
Cheers Guys,
The pop, as far as I can tell came from behind the face plate. If what you say is correct and I'm sure it is I assume buying a new switch will sort out the problem, obviously this time watching how I screw the face plate back into position.
Thanks again.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
pop was at the switch from what i read ( turned the switch on ) and the breaker didn't blow since the rest of the lights still work..
Back to top
 Alert Moderators
sparkydude
from United Kingdom
Thanked: 2 times
PostPosted: Sun Jul 22, 2007 8:26 am    Post Subject:
you have trapped a cable and pinched the insulation to earth, if it worked before you screwed it back then you have either blown the cable apart with the short circuit fault or you have blown the dimmer up. Look behind the switch (with the power off) and you will see the explosion probably.
Nick
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Problem replacing light switch - no idea whats gone wrong! 5 660 Wed Sep 28, 2005 3:21 pm
Problem Replacing dimmer with standard 14 700 Wed Aug 23, 2006 9:58 pm
problem replacing 'Nettle' wall socket 7 340 Mon Jul 14, 2008 6:07 pm
wiring problem & replacing fuses 3 220 Tue Oct 07, 2008 11:12 am
Problem replacing old analogue room thermostat 2 660 Wed Nov 15, 2006 7:43 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
