DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Drain smell
This topic originated from the How to page called Clearing blocked drains
Click here to return to the page called Clearing blocked drains.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Webby54
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 23, 2007 11:12 am    Post Subject:
Drain smell
Reply with quote Thanks
I have a 1930s house with a lean to/utility room at the back. The kitchen sink is directly next to the back door which goes into the lean to room. In the lean to room there is an open drain for kitchen waste and waste from the washing machine.
This drain always smells, and also whenever I use the kitchen sink, the smell comes up through that too.
I cleared the drain a couple of months back and it was blocked with congealed soap from the washing machine. Loads of it. It was disgusting! Anyway, I cleared it all out, but the drain still smells.
The area around the drain hole is very poor and doesnt look to be sealed very well. Its possible that debris from the waste splashes around and gets in the nooks and crannys around the drain.
Would fitting a gully help the situation? Or is there anything else you can recommend?
Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Terrywookfit
from Antarctica
Thanked: 9 times
PostPosted: Mon Jul 23, 2007 12:48 pm    Post Subject:
Is there a trap on the drain?? (Is water standing in the drain)??
Back to top
 Alert Moderators
Webby54
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 23, 2007 1:06 pm    Post Subject:
There is a trap under the drain, cos there is standing water in the drain. It wouldn't be one I could remove though of course as it goes into the ground.
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 9 times
PostPosted: Mon Jul 23, 2007 1:11 pm    Post Subject:
In that case the smell is not coming from the drain!
Seal around the gulley top and make sure that the pipes discharge into it without splashing over the sides!!
Clean regularly with bleach or disinfectant !!
Back to top
 Alert Moderators
Webby54
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 23, 2007 1:18 pm    Post Subject:
Yes, I'd figured it might not be the drain. Trouble is it has no gully. I'll try and describe it. Imagine a box, say a foot square and a foot deep, then at the bottom of that box is the drain, about 8-10inches square. The 2 or 3 inch gap around the drain may be the problem and I did endeavour to point the waste pipes to aim into the drain. It might be an idea to take the drain grill off cos the waste water splashes off of that. Can you buy a plastic gully to fit inside the first box, thereby eliminating the splashes and making it easier to clean?
My next job is probably to remove the trap from under the sink and give it a good clean, then maybe I'll check the water tank in the attic (I read something about nasty things in there that can make your water smell!). I don't mind having a go at stuff.
Cheers
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 9 times
PostPosted: Mon Jul 23, 2007 1:30 pm    Post Subject:
I wish you luck!!
Mind you dont fall in!!!
Back to top
 Alert Moderators
Webby54
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 23, 2007 1:33 pm    Post Subject:
Terrywookfit wrote:
I wish you luck!!
Yes, I've heard stories of dead squirrels and birds in there. I could be gone for weeks before anyone knew!
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 9 times
PostPosted: Mon Jul 23, 2007 1:40 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
stinky smell from kitchen drain 4 2220 Sun Apr 24, 2005 6:21 pm
drain noise & smell 2 1940 Sat Feb 17, 2007 8:29 pm
drain smell 4 800 Fri Dec 12, 2003 4:20 pm
Smell from bath drain 3 720 Tue Mar 14, 2006 4:07 pm
Kitchen drain smell 5 520 Fri Feb 08, 2008 8:27 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
