Joined: 01 Jul 2007 Posts: 13 Location: United Kingdom Thanked: 0 times
Posted: Mon Jul 23, 2007 4:29 pm Post Subject:
optima compact g3 keypad make siren noise
hello i put my alarm on from the mains and pressed everything and then i found out the noise was comming from the keypad i pressed everything and then the noise was still comming then i looked outside the bell box was flashing. wot shall i do as i have got tenants moving in september by the way its a OPTIMA COMPACT G3 control panel.
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Tue Jul 24, 2007 3:54 am Post Subject:
putting in the right code would help.
I am guessing that as you said you turned it on from the mains, it has been off for some time, when it was on some one may have changed the code, so putting in the wrong code will not stop it
__________________ Do you like music Mr Finch?
Forum = Opinions
Joined: 11 Jan 2004 Posts: 16491 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Wed Aug 01, 2007 8:24 pm Post Subject:
I guess you've tried the factory set codes?
Try powering down. Upon powering up, enter program mode using the engineer code, then press reset x 2 within 5s. This will reset the panel to default conditions.
My manual does not mention how to reset the NVM otherwise.
__________________ As George Michael once said, "..if you're gonna do it, do it right, right?"
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
