rgoodwin
Joined: 25 Jul 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Wed Jul 25, 2007 12:29 pm Post Subject: T Into CI Soil Pipe |
I want to fit a new toilet in a downstairs room. Conveniently the soil pipe from an existing toilet runs close by beneath the floor.
However, the existing soil pipe is cast iron.
Is it possible to cut a section out of the Cast Iron pipe, push Multiqwik extensions into each of the open ends, then use slip couplings to connect a standard plastic Equal Branch? Or should Multiqwik extensions only be used in the downstream direction?
If so, is there any other solution?
Cheers.
Richard. |
noseall
Joined: 02 Feb 2006 Posts: 11056 Location: Staffordshire, United Kingdom Thanked: 72 times
Posted: Wed Jul 25, 2007 4:37 pm Post Subject: |
replace the soil stack with a plastic one. |
rgoodwin
Posted: Wed Jul 25, 2007 4:49 pm Post Subject: |
Yes, probably the correct solution, it's just that I can't easily get to either end of the CI pipe - it runs under footings at two sides of the building, but happens to pass through a cellar immediately beneath where I want to site the new loo.
Tapping into the existin cast iron pipe would therefore be much easier.
I don't support there's such thing as a cast iron equal branch with slip couplings?  |
