Dimmer switch wiring
25 Jul 2007
I am just about to fit a dimmer switch which i thought would be straightforwrd but i have just removed the old switch and it is wired as follows:
yellow wire to common
red wire to 1 way conn
blue wire to 2 way conn
now the dimmer switch only has 2 connectors
so any ideas as to how i wire this up where would the 3rd wire go ??
thanks
You need to take your switch back to the shop you bought it from, and buy a 2 way switch.
thanks
is that my only option ?
I dont really mind if the 2 way part is active i suppose not connecting the 3rd wire will not work then eh ?
you say that now, but you will regret it later, take the switch back
if you are not bothered about the other switch remaining operational then it is possible to use your switch.
What wires are at the other switch and to witch terminals are they connected?
A photo would be smashing!!
rf lighting i have just emailed you the picture I hope you dont mind
thanks
To add an image to your post you click the img button. (the "button" is 2nd from the right at the top when you post)
then insert the WHOLE url of the image
then click the image button again
it will look like
Or you can use photo bucket
www.photobucket.com
Once there, the URL including the IMG tags are already shown under the pic so can be copied/pasted without needing to highlight the uRL in a post then add the tags.
luminaire said:
it will look like
I hope not :LOL:
I think you meant to put
[ img]http://www.yourwebsiteaddress/pictures/yourimagge.jpg[/img]
these are the links to the piccy just cut and paste i guess
thanks for all help
__________________________________
Lynda, moderator
I added the
tags for you
thanks sorry new to this !!!
need pics of the other switch and connections too so we can tell you what wire to leave out..
Or you can connect the T & E in the other switch through to the 3 core at the same position and ground the unused core at both ends. Then replace the unused switch with a blank plate. If you do this, don't forget to sleeve the unused core G/Y.
