Joined: 26 Jun 2007 Posts: 15 Location: Kent, United Kingdom Thanked: 0 times
Posted: Mon Jul 30, 2007 5:47 pm Post Subject:
Re: Rendering/wet dash
Tromer wrote:
onion wrote:
tromer do you mean a slurry dash? if so i do 10 pebbles 2 lime 1 cement and 1 sand . do not put any waterproofer in the scratch coat i hope this helps
I intend to use quarter to dust granite chips mixed with sand/cement to match existing. Is this mixture correct and what ratio?
this mix is what i use for slurry dash and i do this in a bucket (small).
as for useing granite , ive never used this as a slurry . try a 10 granite 2lime 1 cement mix and dash a patch to what concistance you want
Joined: 28 Sep 2008 Posts: 3 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Sun Sep 28, 2008 9:14 pm Post Subject:
Slurry dash
Hello onion!! Would you be able to give me some advice on a slurry dash, been asked to do one but never done one.
Or if not the type of thing to be doing blind would you be into giving a metre rate on the job???
scratch coat as normal, let dry for a few days,plaster a light coat of rendering before dashing ,for a large job get an old bath for holding dash.mix enought to do job,the reason for bath is the dash will be the same colour when dry plus a wall uses a lot of of dash.you need a few buckets,quarter fill wet dash from bath into buckets. using a small coal type shovel dash the wall.(maybe a dasher can be bought) they are not difficult to make.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
