DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bathroom installation Connection of Shower and bath waste
This topic originated from the How to page called Drainage Systems
Click here to return to the page called Drainage Systems.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Grenville1M
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 27, 2007 9:09 am    Post Subject:
Reply with quote Thanks
Please can anyone advise me on the connection of shower and bath to a common 43mm waste. I was going to run the waste from the shower tray in the 6" joist space to the outside wall, it runs out under the bath position so I was considering just tee'ing the bath into this run before the waste runs out through the wall to outside.
Is there a chance when emptying the water from the bath that it could back flow into the shower tray given the realatively shallow fall? (shower around 2M from bath) i have asked a couple of plumbers who both said it should be ok as long as there is a decent fall to the waste stack connection. Can anyone confirm this or is there potential to flood the bathroom via the tray.
Otherwise it means running 2 parralel wastes through the wall to the stack on the outside of the house which will look awful
Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Fri Jul 27, 2007 10:34 am    Post Subject:
The bath will drain very slowly so I would think you will be ok to tee into the same pipe.
If you do get a blockage however, it will flow back into your shower tray icon_sad.gif
Try it and see how you get on.
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 9 times
PostPosted: Fri Jul 27, 2007 11:57 am    Post Subject:
Do the job correctly and run separate wastes !!
A soil stack is not something people look at and say "That is really nice"
I feel that you are looking for a reason to cut corners and bodge the job!!
If it is your own home you should want to do it right!!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
WHB Connection into a Bath Waste 4 360 Fri Feb 22, 2008 2:59 pm
Fitting Bath Waste connection 2 520 Fri Apr 13, 2007 1:20 pm
Basic plumbing connection questions for bathroom suite 8 360 Fri Jul 25, 2008 9:51 pm
new bathroom suite-valves and connection questions 6 460 Sun Jul 09, 2006 8:32 pm
shower waste pipe to soil stack connection 3 840 Mon Nov 19, 2007 8:23 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
