JayLar
Joined: 02 Apr 2007 Posts: 7 Location: Bath, United Kingdom Thanked: 0 times
Posted: Sun Jul 29, 2007 10:09 am Post Subject: Partial Soil Pipe Replacement |
We're looking into the possibility of replacing our internal cast iron soil pipe with a plastic one (in the same location). It's not clear to me how easy it will be to gain the access necessary to replace the whole thing which I suspect may make it an expensive job.
If this is the case, is it possible (and practical) to look at a partial replacement of everything above a certain level of cast iron pipe? (with the cast iron portion supported at the wall) |
Dan_Robinson
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
JayLar
Posted: Sun Jul 29, 2007 10:31 am Post Subject: |
We've had a few problems with the existing waste system in the house we purchased. Particularly in the bathroom where the old system has insufficient fall and even rises in part, leading to standing water and the pipes blocking up. Along with some additional problems it seems a good point to replace the whole thing in plastic and reroute some of the waste system.
Only problem is access to the portion below ground level, but everything above i'd envisage replacing if it is possible and sensible. |
Nige F
Joined: 28 Jun 2005 Posts: 7496 Location: United Kingdom Thanked: 32 times
Dan_Robinson
