DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
New Ring main help?
This topic originated from the How to page called Extending a ring circuit using existing sockets
Click here to return to the page called Extending a ring circuit using existing sockets.
  View previous topic :: View next topic
Author Message
PutUmUp
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 18, 2004 8:42 am    Post Subject:
New Ring main help?
Reply with quote Thanks
I\\\'ve just run a new ring main for my kitchen, there are nine double 13amp sockets,when i made it live it was all ok and didnt trip out, but the second i plug ANYthing in it trips. Is due to a short or the MCB is to small in amps??
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue May 18, 2004 9:34 am    Post Subject:
is it the rcd that trips?
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue May 18, 2004 9:51 am    Post Subject:
And is it the same appliance you are plugging in each time?
What size is the MCB? And do the appliances work when plugged in elsewhere?
Is there lots of damp plaster around?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue May 18, 2004 9:54 am    Post Subject:
securespark, the poster said but the second i plug ANYthing in it trips so i should say a variety of items have been tried. my guess is n + E reversal
which is why i figure the rcd is tripping
__________________
Forum = Opinions
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue May 18, 2004 12:47 pm    Post Subject:
He also said "new ring main", so if it's a split-load board the neutrals could be going to the wrong side...
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue May 18, 2004 3:19 pm    Post Subject:
Alright, alright, you bunch of f*cking Sherlocks!!!!
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue May 18, 2004 3:22 pm    Post Subject:
It's over to PutUmUp, The only Red Indian kitchen fitter in the UK!! No offence....
Back to top
 Alert Moderators
PutUmUp
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 19, 2004 4:00 pm    Post Subject:
It is the RCD that trips, i've disconnected every thing, and started again from start, adding on socket at a time, but no change . so i connect the ring to a socket that i know is fine ((in another room via a extension,so i could see if there was a problem with wiring i had ran) and everything works fine, the second i reconnect to the MCB the RCD trips when i switch a device on. I have checked and double check the cables are to the right terminals, and that there is no shorts, it trips even when i created a radial with one socket on the end. thanx for all the help.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed May 19, 2004 7:22 pm    Post Subject:
Is there any damp about??
Back to top
 Alert Moderators
BR
from Ireland
Thanked: 0 times
PostPosted: Wed May 19, 2004 9:12 pm    Post Subject:
damp on the brain!! icon_smile.gif My bet is that he connected the neutral to the wrong block in the CU. N/E reversal seems less likely.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu May 20, 2004 12:30 am    Post Subject:
I said it first. Baggsy the prize if it's right. Feet-shuffling and spreading the blame if it's not....
__________________
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Fri May 21, 2004 2:34 am    Post Subject:
Actuellement, I was called out to a new-build at 3 am one morning to find a dejected young woman (Wa-hey!!) whose RCD had tripped. Spent hours trying to trace how, why, where and when. Failed miserably.
Turned out the walls were a smidge damp and this was having funny effects on the rcd. That's Wylex for you.......
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Diagnosing a ring main installation 8 400 Mon Mar 17, 2008 12:38 pm
Adding sockets to a ring main 9 1120 Sun Aug 13, 2006 9:09 pm
spurs on a ring main? 2 300 Fri Mar 21, 2008 5:43 pm
Extending Ring Main 2 460 Fri Aug 18, 2006 7:57 pm
Upstairs ring main tripping RCD 8 460 Tue Mar 11, 2008 10:10 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
