DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
installing fridge and washer to plug point?
This topic originated from the How to page called Installing wiring for kitchen appliances
Click here to return to the page called Installing wiring for kitchen appliances.
Goto page 1, 2, 3  Next
  View previous topic :: View next topic
Author Message
deancowell
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 1:12 pm    Post Subject:
Reply with quote Thanks
I have recently bought a flat that has had the washer and fridge removed - on inspection, there doesn\\\'t appear to be a normal plug point where the appliances were plugged in, however, there is a socket that resembles an \\\'arial\\\' type socket behind where each unit was which must have been the source of power as both units were in working condition.
Do I need to strip the wiring and if so, could someone talk me through what I need to do?
many thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
CallEdsFirst
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 1:45 pm    Post Subject:
They sound like flex outlet plates, and if so, should be isolated and protected by separate switches and fuses above the worktop. Somebody on here advocated the use of 15amp (not normal 13amp) sockets for this scenario, and I have to say I like the idea. If the supplies are protected and isolatable, it would be best to swap the two flex outlet plates for 15amp sockets, and wire 15amp plugs onto the end of your appliances. If not, then 13amp switched sockets would have to be installed.
Would need more details, i.e. confirmation of above worktop isolation before advocating one solution or the other. The age of the flat is a good indicator, the "kitchen control panels" are a fairly recent implementation.
On a technicality, if wired up in this fashion, are they not installed appliances and therefore part of the fixtures and fittings i.e. you can't take them when you move?
Back to top
 Alert Moderators
Chivers7
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 1:48 pm    Post Subject:
sounds like they are either fused spur outlets. If you turn the power off and open up the boxes there should be a load and supply side inside. You may have to remove the plugs on your appliances and 2hard wire" them in but before doing that are they under guarantee?
Back to top
 Alert Moderators
deancowell
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 1:50 pm    Post Subject:
Thanks for the speedy reply. Yes there appear to be switches (fused)above the counter tops for both units. The flat is a relativly new build, and I would assume that when these were removed, they were simply unplugged from the sockets I described - from behind each unit.
Both were in working order, and I'm hoping to install the units myslef but this is the first time I have seen these type of sockets as opposed to the usual plug points. If I need to re-wire to accomodate a different type plug I may need some asssistance as I'm a true DIY NOT.
The owner didn't include them in the sale, and were therefore removed unfortunately.
Back to top
 Alert Moderators
deancowell
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 1:54 pm    Post Subject:
the items (washer and fridge) are brand new - can you talk me through 2 hard wiring them?
Back to top
 Alert Moderators
CallEdsFirst
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 1:56 pm    Post Subject:
The things on the wall under the worktop are not likely to be "sockets", but flex outlet plates as stated. Like Chivers said, this means cutting plugs off and hard-wiring. Photos would confirm this!
Back to top
 Alert Moderators
deancowell
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 1:59 pm    Post Subject:
Thanks - if flex outlet plates look similar to a wall arial socket then this sounds right - I'm away from the prop now but will perhaps send some pics to confirm - it sounds like I need to learn how to hard wire them??
Back to top
 Alert Moderators
CallEdsFirst
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 2:08 pm    Post Subject:
http://www.toolstation.com/images/library/stock/webbig/89435.jpg
No coaxial/aerial connection, just a hole!
Back to top
 Alert Moderators
deancowell
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 3:00 pm    Post Subject:
yes - thats it. Any advice on how I need to wire the plug?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Jul 31, 2007 3:01 pm    Post Subject:
it is also possible to remove the flex outlets and fix ordinary 13A unswitched sockets in their place. This means you can use the plugs provided with the appliances and it is very much easier to install and remove them.
It wil be tiresome if you have a fuse blow, but this is very rare.
Back to top
 Alert Moderators
CallEdsFirst
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 3:13 pm    Post Subject:
Will you stop coming in here and suggesting simple, uncomplicated suggestions that are just as good as my own "can't see the wood for the the trees" ideas!!!!! icon_mad.gif
Back to top
 Alert Moderators
deancowell
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 3:16 pm    Post Subject:
any advice on how to do either would be appreciated - is there a site I can go to for a step by step guide?
Back to top
 Alert Moderators
CallEdsFirst
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 3:25 pm    Post Subject:
Behind the plate should be three wires, probably:
Red - Live
Black - Neutral
Green and Yellow sleeved copper - Earth
Put these in the terminals as marked, although any socket you might buy today will probably be marked:-
Brown - Live
Blue - Neutral
Green and Yellow - Earth
Just make sure to isolate it first, and if you don't feel you can do it safely and competently, get someone in. It really ought to be a ten minute job and not cost you the earth(not the green and yellow cable, but the planet we inhabit this time)
Back to top
 Alert Moderators
davelx
from United Kingdom
Thanked: 6 times
PostPosted: Tue Jul 31, 2007 3:30 pm    Post Subject:
There is no plug! You need bare ends on the flex.
Cut the plug off the appliance (standard warning that this might void the warranty - check the users guide). Strip back the outer sheath of the flex, and strip suitable amount of the conductors (look inside the flex outlet first to judge the lengths needed - see below)
If you take the faceplate of the flex outlet, you will see three terminals and a cable grip. FIRST: Pass the flex through the faceplate (don't forget to do this before you connect up)! , then under the cable grip and connect the three cores to the appropriate terminals in the usual way. Tighten cable grip onto outer sheath of flex, screw faceplate back on and the job's done.
PS: and now you have a guide to both approaches icon_smile.gif
Back to top
 Alert Moderators
CallEdsFirst
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 31, 2007 3:34 pm    Post Subject:
WHOA THERE!
There is a plug if you are putting in 13amp unswitched sockets.
Try and keep up Davelx!
I can see poor Dean ending up with the same situation but reversed!!!!
"Right, socket installed, now cut plug off, Oh French Connection United Kingdom!"
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 3
Jump to:
Installing FCU's for washer/dishwasher 11 880 Wed May 16, 2007 12:11 pm
Positioning washer-dryer power socket 5 520 Mon Oct 18, 2004 5:08 pm
Washer/Dryer/Cooker clarification 4 440 Fri Mar 10, 2006 11:21 pm
FAULTY WASHER??? 5 240 Mon Apr 13, 2009 10:58 am
Pressure washer not working 6 160 Mon Aug 31, 2009 5:56 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
