DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Alpha CB28 - Intermittent Loud Vibration
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
greyrock
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 01, 2007 6:50 am    Post Subject:
Reply with quote Thanks
We have a 3 year old Alpha CB28 Combi. All radiators are also 3 years old. No problems whatsoever and good hot running water.
Three days ago the boiler started vibrating loudly for 20 mins at a time and then nothing for 10 hours. Noise stops if either tap is turned on.
Had it serviced was told it's clean and running v efficiently. I was expecting that the service would at least identify the problem.
Plumber mentioned that we could run a cleaner through the radiators but they've not been on since April/May and turning it on doesn't stop noise.
Any ideas?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Wed Aug 01, 2007 10:32 am    Post Subject:
It sounds like a mains water supply pipe resonance.
Its probably nothing to do with the boiler and might originate from a WC cistern refilling.
Try tieing up the noise with water usage including washing machines etc.
Tony
Back to top
 Alert Moderators
greyrock
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 02, 2007 11:44 am    Post Subject:
Thanks Tony
I think/hope I've found the source.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Fri Aug 03, 2007 11:44 pm    Post Subject:
So what do you think it might be ???
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potty Suprima 120L, Loud Vibration On Fire Up 35 2200 Sat May 20, 2006 6:30 pm
loud humming vibration coming from loft tank 2 380 Wed Aug 17, 2005 5:28 pm
Loud vibration when taps are on. 9 520 Sun Jul 23, 2006 3:42 pm
Loud Vibration from new well pump? 3 260 Sat Mar 20, 2004 5:24 pm
Loud noise/vibration after flush 2 1120 Wed Dec 20, 2006 11:48 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
