DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting neon indicator switch
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
Frengineer
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 02, 2007 12:50 pm    Post Subject:
Reply with quote Thanks
I need to fit a neon indicator switch in place of an ordinary light switch. Unfortunately there is only one wire to and from the switch (plus an earth).
The new switch is a double pole switch with the neon wired across the two bottom terminals.
I understand that I also need a "neutral" wire to make it work properly.
Where do I find a neutral wire?
How do I wire up the switch?
Frengineer.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
tim west
from United Kingdom
Thanked: 15 times
PostPosted: Thu Aug 02, 2007 4:52 pm    Post Subject:
some old neon indicator switches used to have the indicator across the switch ie across live and switchline the neon was on when the switch was open and off when made it basically ended up in series with the lamp and the switch shorted the neon or not accordingly.
The main use of this was to locate switches in the dark.
if you wish the neon on when the light is then you will need to rewire a neutral to the switch (three core and earth from rose to switch).
Back to top
 Alert Moderators
sparkmanc
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 02, 2007 5:25 pm    Post Subject:
..or perhaps a double insulated singles cable would be easier, if the installation is in steel conduit.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Aug 02, 2007 5:29 pm    Post Subject:
well if it is in steel conduit (doubtful) double insulated wire is not required
Frengineer, why do you want this switch?
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Frengineer
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 03, 2007 4:02 pm    Post Subject:
Thank you all for the replies.
I need the switch to tell me that the bathroom fan is going.
The long story is that I wanted to dim the (new) lights and had a pull dimmer fitted (inside the bathroom). This setup didn't kick the fan control because (I think) the dimmer switch reduced the output voltage. So now the outside switch switches the whole lot on. What happens now is that when somebody turns the lights off with the pull switch it leaves the fan going (it is very quiet).
Hence the need for the neon.
Frengineer.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Aug 03, 2007 5:27 pm    Post Subject:
why not fit a big neon in its own box above the outside of the bathroom and run a cable directly to the fan?
__________________
Forum = Opinions
Back to top
 Alert Moderators
sparkmanc
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 03, 2007 6:17 pm    Post Subject:
I actually just mean a conduit drop for the switch buried in the wall (Pretty common) - not the whole system.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Neon indicator pull switch 9 280 Thu Jul 23, 2009 11:44 am
Pull Cord Switch With Neon Or On/Off Indicator 9 460 Tue Sep 16, 2008 7:27 pm
socket with unswitched neon indicator 8 520 Mon Dec 10, 2007 8:26 pm
Shower neon indicator light not working 4 260 Sun Dec 07, 2008 6:18 pm
Proving that a GS38 voltage indicator is working? 6 940 Mon Mar 21, 2005 10:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
