DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
render advice
This topic originated from the How to page called Rendering
Click here to return to the page called Rendering.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
  View previous topic :: View next topic
Author Message
chris.r
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 04, 2007 10:39 am    Post Subject:
render advice
Reply with quote Thanks
Gentlemen, I have a knackered rendered wall to deal with.
I have removed unsound render , some of which has been caused by brick spalling and I am left with a patchwork quilt of bare brick/sound render.
I intend to patch the exposed brickwork with a render mix of 1:2:2 cement/sharp sand/building sand. Is this mix advisable? Should I add a diluted unibond solution to the wall prior to rendering? At what stage if any should I use waterproofing agent?
Then I plan to cover the whole wall in a Tyrolean mix, again when to use waterproofer?
Finally a masonary paint is to be applied, or would I be better off with a \\\"rubberised\\\" paint. You guessed it; when to waterproof ! icon_exclaim.gif !
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 72 times
PostPosted: Sun Aug 05, 2007 5:48 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
Advice on external render beading 15 3160 Sun Feb 10, 2008 10:50 am
EXTERNAL RENDER ADVICE / TIPS NEEDED 7 540 Fri Sep 25, 2009 11:02 am
Advice on new Render 22 1540 Thu May 14, 2009 9:36 pm
Lath and plaster ceiling repair. Advice needed please. 3 820 Mon Feb 18, 2008 2:59 pm
rendering advice please :) 3 640 Tue Apr 01, 2008 9:50 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
