DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Unvented below sink water heater- PRV drain
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
4xpaws
from United Kingdom
Thanked: 1 time
PostPosted: Sun Aug 05, 2007 10:46 am Reply with quote
I'm having a 'below sink' unvented water heater installed in the loft. It needs a pressure relief valve installed in the pipework along with it. Has the drain coming from the PRV & tundish got to be copper? or can it be PE-X barrier pipe?
Back to top
 Alert Moderators
Doctor Drivel
from United Kingdom
PostPosted: Sun Aug 05, 2007 11:01 am Reply with quote
Avoid these. Fit a heat bank thermal store.
Back to top
 Alert Moderators
4xpaws
from United Kingdom
Thanked: 1 time
PostPosted: Sun Aug 05, 2007 11:48 am Reply with quote
Thanks for comment.
One reason amongst others is too long a pipe run is needed to fit thermal store. 30m+ run needed. Its for 3rd floor and storage cylinder's in basement.
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5357 times
PostPosted: Sun Aug 05, 2007 12:56 pm Reply with quote
What make and model?
I think it would have to be copper.
What are you feeding with it?
Why not fit a secondary return - much lower running costs and less maintenance.
Back to top
 Alert Moderators
4xpaws
from United Kingdom
Thanked: 1 time
PostPosted: Sun Aug 05, 2007 1:16 pm Reply with quote
Speedlow SF10Li unvented water heater
feed from mains.
Secondary return -what's all that about? Returning to where?
Back to top
 Alert Moderators
jay1
from United Kingdom
Thanked: 12 times
PostPosted: Sun Aug 05, 2007 1:35 pm Reply with quote
does it need to have prv and tundish if it is storing less than 15 litres, im pretty sure its doesnt need to.
Back to top
 Alert Moderators
Doctor Drivel
from United Kingdom
PostPosted: Sun Aug 05, 2007 2:29 pm Reply with quote
4xpaws wrote:
Thanks for comment.
A DHW secondary circulation pump can be fitted to a thermal store heat bank.
Back to top
 Alert Moderators
4xpaws
from United Kingdom
Thanked: 1 time
PostPosted: Sun Aug 05, 2007 2:37 pm Reply with quote
Comes supplied with PRV + all fitting senarios show the 6 bar PRV installed.
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5357 times
PostPosted: Sun Aug 05, 2007 2:39 pm Reply with quote
Its basically just a loop going back to the cylinder that re-circulates the hot water using a bronze pump set on a timer/timer & thermostat so that the hot water doesn't take three weeks to get to taps at the opposite end of the house. Hotels use it as do hospitals.
You haven't answered the main quetion of what it's for.
DD the man doesn't need a thermal store; leave it - for a change.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 861 times
PostPosted: Sun Aug 05, 2007 2:43 pm Reply with quote
Fraid not, they come with a PRV and you have to allow 4 meters of supply 15mm pipe for expansion back up the supply pipe before a draw off on said supply.........or 2 metres of 22mm pipe icon_wink.gif I would run copper and use a 22x35 reducer as a tundish.......in fact I`ve done 2 now ,as they are not covered by unvented certificating icon_wink.gif which I aint got
Back to top
 Alert Moderators
4xpaws
from United Kingdom
Thanked: 1 time
PostPosted: Sun Aug 05, 2007 2:47 pm Reply with quote
Pipe run involved means its too costly in terms of labour & materials + access needed to install run is difficult. Forget it.
The heater's bought and now needs fitting (correctly)!
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5357 times
PostPosted: Sun Aug 05, 2007 2:49 pm Reply with quote
You are welcome.
Back to top
 Alert Moderators
4xpaws
from United Kingdom
Thanked: 1 time
PostPosted: Sun Aug 05, 2007 3:22 pm Reply with quote
Its to supply a sink in a 3rd floor bathroom. Boiler and cylinder a down in basement. Cold tank is on the 3rd floor too. Previous plumber said the under sink heater was the best option for getting hot water to 3rd floor sink.
-The fitting instructions show at least 2.8m of 15mm pipe is needed for expansion to the nearest cold draw off from the heater. As the curent main supply is 15mm, adding reducers and a section of roughly 1.3m of 22mm between the nearest cold draw off and the 15mm fitting to the heater is acceptable??
Fitting a length of 22mm -would this step up the the size pipework needed for the PRV discharge? Currently with the PRV Tee'd off 15mm supply, discharge pipe D1 (PRV to tundish) is 15mm & D2 (tundish to outside) is 22mm.
With this 22mm 'expansion' section would D1 now become 22mm and D2 28mm??
-Finally, can the PRV drain pipe discharge onto a roof, or has it got to go 3 story's down to a surface drain, or... can it vent into the cold water/ DHW cistern?
I'm a bit bemused you can't use barrier pipe for the drain given that you can use it for other HW CH applications.
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5357 times
PostPosted: Sun Aug 05, 2007 3:35 pm Reply with quote
You want to use a 10 litre unvented heater to run a bathroom?
hhhmmmm. Are you sure?
I wouldn't terminate it over the roof unless you had at least three metres of surface before it entered the guttering.
It would be a copper pipe as the PEX pipe might not handle the superheted water/steam that is released under fault conditions.
Hence avoiding the termination of the Safety discharge over the roof.
I don't think you quite understand how all this works do you?
The size of the incoming main has little bearing on what happens after the heater with regards the safety discharge.
Back to top
 Alert Moderators
Balenza
from United Kingdom
PostPosted: Sun Aug 05, 2007 4:12 pm Reply with quote
Dan Robinson wrote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Installing Under Sink Water Heater - Unvented? 4 840 Mon Mar 02, 2009 10:05 pm
indirect unvented water heater Q (and wireless thermostat Q) 2 60 Fri Oct 21, 2011 3:08 pm
Problem with my Unvented water heater - OSO indirect 210 2 60 Thu Aug 08, 2013 8:49 am
Unvented cylinder with Johnson and Starley water heater 3 20 Sat Nov 09, 2013 11:29 am
indirect or direct unvented water heater 2 200 Mon Nov 01, 2010 7:04 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
