mrpurton
Joined: 31 Jul 2007 Posts: 11 Location: London, United Kingdom Thanked: 0 times
Posted: Sun Aug 05, 2007 2:15 pm Post Subject: leek under basin bathroom |
please can you tell me if this is ok to do i brought an italian vanity unit with a basin and mixer tap with pop up waste . i took out the pop up waste and used a whole new british waste not pop up . under the sink it wont stop dripping is it the wrong waste i put in. its the same mixer tap just a new waste system not pop up. help please. i used plumbers mait. lots of. still wont stop dripping. do i have to use the same as they sent me. it seem to fit is it to do with under the plug do you think it seems to fit. i cant think where the drips comeing from i used a torch to check it. mr purton fed up |
Dan_Robinson
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Sun Aug 05, 2007 2:34 pm Post Subject: |
leeks are not good under vanity units - they go smelly.
Much better to make a soup.
As far as your waste is concerned... Plumbers mait is useless IMHO. The correct washers and some silicone should be all thats required.
Don't overtighten the back nut of indeed the trap's nuts; otherwise Mrs Purton will crush your nuts when she can't use her new vanity basin.
Disassemble everythnig and redo as I have suggested and you'll be fine.
I assume the new waste sits snugly into the whole of the basin? and that you have the correct slotted/unslotted waste depending on the overflow arrangement? __________________ Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man |
chr15
Joined: 22 Jun 2004 Posts: 537 Location: Carmarthenshire, United Kingdom Thanked: 0 times
Posted: Sun Aug 05, 2007 3:22 pm Post Subject: |
Mr purton, if you go to plumb center,they sell a big rubber washer called a 'basin mate', about a quid, if you put one of these on and follow the instructions that come with it you will not get a leak--or a leek  ,they are chamfered so they fit into the waste opening really well when you tighten them down-none of the ones I have fitted have ever leaked so I always use them on basins, beware, they dont work very well with pop-up waste cos the washer is that big it fouls on the pop-up gear. Hope this helps. Chris |
mrpurton
Posted: Sun Aug 05, 2007 3:33 pm Post Subject: |
i will give it atry thank you dan |
mrpurton
Posted: Sun Aug 05, 2007 3:34 pm Post Subject: |
thank you chris i will try this as well as i want no leaks |
