DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing ball valve of tank in loft
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
SammyT
from United Kingdom
PostPosted: Sun Aug 05, 2007 6:04 pm Reply with quote
I need to change the ball valve of the tank in the loft. There is a stopcock on the pipe leading to the tank. The reason I need to change the ball valve is that even after bending the arm to the float the valve is still leaking and causing the water to go down the overflow at most inopportune times (ie at 3.00am and waking me up!). I have a couple of questions....
How do I know what size I need to buy 1/2 inch or 3/4 inch - the tank feeds the hot taps?
Having looked on the internet for purchasing a ball valve there was a site which talked about valves for low or high pressure, how do I know which I need?
How do I go about replacing the ball valve?
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5478 times
PostPosted: Sun Aug 05, 2007 6:41 pm Reply with quote
You need a half inch part-two high pressure ball valve.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun Aug 05, 2007 9:24 pm Reply with quote
Please don't buy one on the Internet - there's very little saving to be had, and it will cost you an arm and a leg in hassle if it arrives faulty or damaged.
Just walk in to your local plumbers' merchant and ask for exactly what Dan specified. Get a new float as well and screw on the float before installing the valve.
If you already have a compatible float valve, then just undo the joint on the part that's inside the cistern, and leave in place the part connected to the cistern. This way you can leave undisturbed that joint that's more likely to leak, and more of a problem if it does.
You'll probably drop the fibre washer into the cistern, but at least I've warned you about it. icon_biggrin.gif
Back to top
 Alert Moderators
SammyT
from United Kingdom
PostPosted: Tue Aug 07, 2007 3:47 pm Reply with quote
Many thanks for your advise, I'll certainly follow it and buy a 1/2 inch high pressure valve from a local plumbers merchant.
Now to be really cheeky.....
As i have no DIY skills and would like to learn, is it a difficult job to replace or is it best to get a plumber in? if it's not a too difficult job, can anyone please give a few instructions that might help.
Thanks again
Back to top
 Alert Moderators
Mike2007
from United Kingdom
Thanked: 17 times
PostPosted: Tue Aug 07, 2007 3:55 pm Reply with quote
Wear a head torch, makes job easier. Its a really simple job to do without much knowledge!
Top Tips. You should not be left with "spare parts" once completed icon_confused.gif
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5478 times
PostPosted: Tue Aug 07, 2007 4:26 pm Reply with quote
Your mantra with the spanners should be
"equal and opposite force".
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Tue Aug 07, 2007 8:32 pm Reply with quote
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5478 times
PostPosted: Tue Aug 07, 2007 8:40 pm Reply with quote
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Tue Aug 07, 2007 8:45 pm Reply with quote
Replaced a basin tap valve body last week (amongst many), but only after the owner had "had a go himself". He'd mangled everything, loosened the backnut, and made the tap connector leak.
He went into the kitchen and turned on the kettle, during which time I'd turned off the ball-o-fix and remove the valve body. Stunned, he asked me how the **** I'd done that.
"The right amount of force in the right direction", I said smugly. icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Replacing a loft tank ball cock - it's leaking!! :( 9 10360 Wed Feb 04, 2009 10:09 pm
Loft cold water tank ball valve 12 240 Sat Jan 03, 2015 9:12 pm
Cold Water Tank in loft - constant drip from ball valve 3 500 Wed Nov 17, 2010 10:15 am
Whistling loft ball valve (after toilet refill) 8 1480 Wed Mar 05, 2008 6:12 pm
Replacing Ball Valve in Hot Water Header Tank 8 3460 Fri Sep 09, 2011 10:32 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
