DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Joining chrome waste pipe to PVC
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Jimbo
from United Kingdom
Thanked: 1 time
PostPosted: Wed Aug 08, 2007 7:55 am Reply with quote
I have a PVC waste pipe set into the concrete in my downstairs toilet. I'm putting a new suite in, with chrome bottle trap and waste pipe. I need a way to connect the chrome pipe to the PVC pipe at floor level. I'm laying tiles so have perhaps 3/4" to play with before the joint comes proud of the tiling - obviously not enough to put a dirty great compression joint.
Are there any internal joints available for this sort of thing?
Dias/Bores are as follows (mm):
Chrome pipe 35/33
PVC pipe 35/32.
This is the sort of thing I have in my mind's eye...
Jim
Back to top
 Alert Moderators
petetheleak
from United Kingdom
Thanked: 1 time
PostPosted: Wed Aug 08, 2007 8:37 am Reply with quote
Not that I know of .Internal joints would increase the risk of obstruction.You also need a wee bit more length on your present pipe .Prob the only way to go is try and fit McAlpine coupling and spray it silver, or make joint under floor.
Back to top
 Alert Moderators
Jimbo
from United Kingdom
Thanked: 1 time
PostPosted: Wed Aug 08, 2007 10:37 am Reply with quote
Yep, I was aware of the potential for obstruction, but with the traffic the downstairs loo receives I wasn't particularly worried! Nobody's washing their hair in the sink or anything!
Digging the floor up is a no-no. I'd already decided I didn't want to do that, but I've now laid the majority of the tiles on the floor, and I don't want to risk a crack propagating underneath them!
I'm tempted to improvise with a 3" length of 1 1/4" PVC pipe with a ~5mm slit down the side, pinched together to make a smaller bore pipe and fixed within the two pipes I want to join. I'm sure this will stand up to the potential pressure created by filling a small sink! However this will reduce the bore by over 10%...
Back to top
 Alert Moderators
chrisey
from United Kingdom
PostPosted: Wed Aug 08, 2007 10:43 pm Reply with quote
Core cutter around pipe in the floor to a couple of inches and chipout loose concrete. clean pipe . use a screw type plastic connector with rubber seals and as an extra precaution some silicone. should be know problem to connect your chrome pipework to. icon_rolleyes.gif : chrisey
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5448 times
PostPosted: Wed Aug 08, 2007 10:48 pm Reply with quote
Back to top
 Alert Moderators
chrisey
from United Kingdom
PostPosted: Wed Aug 08, 2007 11:13 pm Reply with quote
A few times Dan, when the pipes been hit and broken with the hover. icon_lol.gif
Back to top
 Alert Moderators
Jimbo
from United Kingdom
Thanked: 1 time
PostPosted: Thu Aug 09, 2007 8:06 am Reply with quote
Thanks, I'll give it a go!
Back to top
 Alert Moderators
Jimbo
from United Kingdom
Thanked: 1 time
PostPosted: Mon Aug 20, 2007 8:52 am Reply with quote
Chrisey
Thinking about this whilst on holiday last week (British Summer weather gives plenty of opportunity to just sit and think!), it occurred to me that if I use a core cutter, there's nowhere for the arbor bit to locate so the core bit will just skip around all over the place. How did you overcome this?
Cheers
Jim
Back to top
 Alert Moderators
chr15
from United Kingdom
Thanked: 6 times
PostPosted: Mon Aug 20, 2007 8:57 am Reply with quote
Well what I would do is make a template with a piece of thin plywood or even hardboard will do if you have nothing else. Just drill a hole thru the template the same size as the one you want to drill in the concrete and then use that by standing on it and drilling thru the hole to give you a smooth start-done it many times with holes up to 200mm diameter a few years ago when in a different trade.
Back to top
 Alert Moderators
Jimbo
from United Kingdom
Thanked: 1 time
PostPosted: Mon Aug 20, 2007 9:01 am Reply with quote
Excellent solution, thanks very much!
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5448 times
PostPosted: Mon Aug 20, 2007 4:31 pm Reply with quote
Jimbo wrote:
Chrisey
Cheers
Jim
Not for the practiced.... I couldn't find my guide/pilot drill for ages, but I managed plenty or neat holes tah very much.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Mon Aug 20, 2007 6:51 pm Reply with quote
I would consider cutting a plug to fit the end of the waste pipe from a bit of scrap timber, and drill it to take the pilot bit.
Back to top
 Alert Moderators
Mike2007
from United Kingdom
Thanked: 17 times
PostPosted: Mon Aug 20, 2007 7:05 pm Reply with quote
I have a good solution but fear all here will call me a cowboy??
Put some lubricant on the end of the chrome pipe (this assuming the very similar size diameters) and gently warm the inside of the PVC pipe. Once the PVC pipe is "leathery" gently insert the cooler chrome pipe. You must very slowly keep turning the metal pipe keeping it plumb upright!
Both will cool and you are left with a tight socket in the PVC end, pull it out clean it up them finally use a little silicone to make a union.
Yes, I know very cowboyish! icon_redface.gif BUT, it works!
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5448 times
PostPosted: Mon Aug 20, 2007 8:04 pm Reply with quote
Far from it, I and several of my guys have used this kind of technique in slightly different applications several times. You have to be very careful with te blow torch though...
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Mon Aug 20, 2007 8:16 pm Reply with quote
Maybe a hot air paint stripper would be a little bit kinder to the pipe than a blowlamp......
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Joining brass/chrome basin waste to solvent weld? 4 120 Sat Jul 21, 2012 12:33 pm
Joining 32mm metal waste pipe? 3 680 Sun Feb 05, 2006 12:43 am
Joining Kitchen Waste to Cast Iron Soil Pipe? 3 400 Tue Nov 25, 2008 1:41 pm
joining lead pipning to plastic pipe (bath waste) 5 1220 Fri Feb 06, 2004 1:14 pm
Joining waste pipe to caste iron soil stack (brass thread) 7 200 Wed Jun 01, 2011 11:39 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
