DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dimmer switch and related
This topic originated from the How to page called Choosing the correct size flex
Click here to return to the page called Choosing the correct size flex.
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK
  View previous topic :: View next topic
Author Message
PHD
from Australia
Thanked: 0 times
PostPosted: Sat May 22, 2004 6:06 am    Post Subject:
Reply with quote Thanks
When installing a dimmer switch to control several down lights or, installing a 3 speed fan and switch, is the normal 3 wire flex suitable or do I run a different type of cable/flex, It seems to me thatI may need a 4 wire cable? I want to have the correct cable in place as I construct. The electrician will be able to hook up with out running cable later to the above items??
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ZenStalinist
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 22, 2004 8:34 am    Post Subject:
The three wire cable is suitable. Flex is not, use proper cable. Four wire cable is for two-way switches. However, I don't have much knowledge of Australian wiring A light fitting with an electric fan should not be controlled by a dimmer switch.
I think what you might be referring to on the fan is a 'loop' switching system. If you see the post entitled 'For Reference' it will show you a diagram of how it is done. If you don't have a loop installation and want to use the fan, don't worry, connect the switched live to the block marked 'loop', and don't bother with the connector marked 'live'.
Back to top
 Alert Moderators
PHD
from Australia
Thanked: 0 times
PostPosted: Sat May 22, 2004 9:34 pm    Post Subject:
wiring for dimmers & 3 speed fan
Thanks for the help. I am only intending to run cable as I install walls etc and I take it standard3 wire cable is Ok for both lights and fan.
Back to top
 Alert Moderators
AdamW
from Vatican City State
Thanked: 0 times
PostPosted: Sun May 23, 2004 1:32 am    Post Subject:
We used to have a British spark working in Australia on this forum, it's a shame he doesn't appear to be about anymore! icon_biggrin.gif
From what I understand, in Australia you MUST have all electrical work signed off by a licenced electrician. You might want to find an electrician willing to sign your work off before you do it, it may be that they don't want to/can't legally sign off someone else's work. Which would mean a whole lot of mess and holes cut in your nice new walls to get new cables in.
Also, try to find out what kind of cable you are allowed to use. In the UK, it is not acceptable to use flex in fixed wiring. This may be different in Au, but if you aren't absolutely 100% certain, try to find a recent book on domestic wiring. Your local library might have one.
Can I just say, "hahaha, it is nearly summer here, and nearly winter there now. Hahahaha!" icon_lol.gif
Back to top
 Alert Moderators
PHD
from Australia
Thanked: 0 times
PostPosted: Sun May 23, 2004 6:22 am    Post Subject:
Thanks Adam> Yes I do have to have an electrician do the work and sign it off, The cable I am running is correct, just wanted to make sure I don't need a 4th cable for 3 speed fan install.
AND sooner have an Aussie winter in Queensland than a UK summer, been therte done that, I am still drying out
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
Couple of French electrics related Q's 2 320 Sat Sep 12, 2009 12:55 pm
How to rewire a slide-type dimmer switch (France) 5 980 Fri Feb 11, 2005 4:20 pm
1Way Dimmer to a 1 way switch, weird black plastic box 6 860 Thu Nov 09, 2006 9:12 pm
dimmer switch help 19 1640 Wed Nov 30, 2005 6:24 am
Looking for a certain dimmer switch 3 1760 Mon Sep 25, 2006 4:49 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
