DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
tongues not going into the grooves
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
simonmotorbike
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 10, 2007 7:18 pm    Post Subject:
Reply with quote Thanks
PROBLEM
I am putting down a laminate floor. Trying to. I have got as far as the second row of planks, and the tongues just wont go in the grooves. I am hitting them with ever increasing size of hammer, but no luck.
I have done this before, and it all went very well - I just can\\\'t see what is wrong.
DETAILS
The laminate is about three mil. of oak, with MDF underneath, going onto a level concrete floor with a foam underlay. It is the floating kind, with tongue and groove fixing. The tongues have a small blunt \\\"arrowhead\\\" which should be clicking into the groove. But they aint.
I am a little kit of wedges etc made for the purpose. And the planks have spent a good time in the room getting used to the conditions.
IDEA
Could it be that the humidity and heat of the moment (both are pretty high) is causing the tongues to expand? Thus stopping them fitting where they should?
I have noticed that the planks are less than flat - there\\\'s a noticable bowing to some. Again, this could be the humidity and heat? Would this be a factor in misaligning the tongues and grooves?
Any ideas?
Simon
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Fri Aug 10, 2007 7:41 pm    Post Subject:
it can be down to the humidity which in turn has made the wood take in to much moister but you wont know this unless you can take a moister reading of the wood. Which you need a wood species meter to test. I dought this is your problem tho. Is it a glue,lock or tap system? Which make of wood is it?
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sat Aug 11, 2007 8:29 am    Post Subject:
Re: tongues not going into the grooves
Last time you might have had a better quality laminate? Half the work is in the quality you buy.
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
yandownie
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 12, 2007 10:19 am    Post Subject:
have you tried presenting the floorboards at about a 30 degree angle to the already laid ones and seeing if they click into the grooves that way ?
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 26 times
PostPosted: Sun Aug 12, 2007 12:00 pm    Post Subject:
is it click type or glue type!!!
are you using the propper fitting block or a large enough off cut [if its glue type]to protect the edge whilst you tap it!!!
are as said above approaching at an angle with thr click type !!!
have you checked the grooves are clear !!!!
sometimes if you not carefull you may get the underlay trapped in the joint !!!
if you are finnishing up with uneven gapps you may need to adjust the packers against the wall to give you a strait edge
have you tried 2 planks from the same box[maybe another fresh box] to see if they go together!!!!
__________________
big all
we are------------------ all still learning
Back to top
 Alert Moderators
eclomaxkiwi
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 03, 2009 10:24 pm    Post Subject:
tongues not going into grooves of T&G flooring
Try rubbing the tongues with a candle. Good for sticky saws as well. Wax is a good lubricant.
Use a club hammer against a scrap piece of flooring.
It worked for me.
Back to top
 Alert Moderators
eclomaxkiwi
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 03, 2009 10:30 pm    Post Subject:
Tounges not fitting grooves
Make sure the planks are well supported against the skirting. If the skirting/wall is curved then the boards will bounce when hit. I use scraps of flooring not the cork nor the wedges or the skirting.
Back to top
 Alert Moderators
Mark Elvin
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 05, 2009 2:45 pm    Post Subject:
Hmm, tongue not going into groove....my wife would file for divorce!!!!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
