DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
jaguar23kw combi prob
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
whothehellinstalledthat
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 11, 2007 2:35 pm    Post Subject:
Reply with quote Thanks
hello...called out to a jaguar boiler(which ive only ever installed ...never had to repair one)when either calling for hw or heating the fan starts and then cuts out when air pressure switch makes contact ,ie fan cycles on and off constantly....air pressure switch appears ok ...no fault code on display....suspect pcb maybe?...any help welcome
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
SvenVanLagerTop
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 11, 2007 3:07 pm    Post Subject:
Sounds to me like a pcb problem mate. Potterton Profiles give the exact same fault and the pcb turns out to be the culprit every time. Never found this on a Jaguar before but the pcb would be favourite for me. icon_wink.gif
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sat Aug 11, 2007 3:08 pm    Post Subject:
Has to be the shortest fault finding section of any combi boiler manual!
Either the fault is one which falls in the cracks between the error codes, or the thing which should be displaying them, ie the pcb, is bust.
Just worth checking the aps resistances, etc. Lube the fan to see if it speeds up, clean venturi...
Could try simulating the aps with a microswitch.
In other words, dunno mate. I'd be on the phone to HeatCall on Monday.
Back to top
 Alert Moderators
corgigazza
from United Kingdom
Thanked: 5 times
PostPosted: Sat Aug 11, 2007 5:03 pm    Post Subject:
these have a main control pcb and ignition pcb on the gas valve it will be the ignition pcb pt no at hrpc 441087had one similar go on a sunnier duval was suprised it was the ig pcb not the main pcbhttp://www.partscenter.co.uk/parts/index.html
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Sat Aug 11, 2007 6:07 pm    Post Subject:
Are you 100% sure the APS contact leads are correctly connected before you buy the ign pcb?
Suggest you remove tube to confirm fan runs continuously. Then check microswitch contact resistance.
That failure of the ign pcb is unusual though.
Tony
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 9:34 pm    Post Subject:
jaguarr prob
thanks for the help lads its been appreciated,
the special prize goes to corgigazza....ignition pcb u/s
thanks again
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vokera Linea 726 combi boiler prob 3 60 Tue Nov 10, 2009 1:35 pm
flow switch prob with halstead combi boiler 5 500 Tue Sep 23, 2008 7:10 pm
Valliant Combi Prob: hot water goes cold when shower is on.. 6 920 Mon Nov 15, 2004 10:14 am
Help!! Ravenheat combi prob - central heating not working:( 4 960 Sun Nov 06, 2005 8:17 am
vaillant combi prob 4 520 Wed Feb 25, 2004 9:19 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
