potterton suprima 80 question , does green light come on for
12 Aug 2007
Essex
hot water as well as heating , we had problem recently where the hot water only worked if heating was on aswell had it fixed but in this hot weather we only want hot water , now the timer control light comes on and goes off at the right time but nothing actually happens to the boiler (light stays red) should this fire up for hot water aswell as heating ( when press boost for heating for example all ok - but press boost for hot water just red light on timer control comes on but no bolier action - is this right? )
is it a potterton programmer by any chance , with the sliders for HW & HTG, If so its probably faulty. regards chrisey.
Yes - the boiler does not know what it is doing. The external controls come on and temperature/settings permitting the boiler will fire unitl:
a: system water reaches boiler's set temperature
b: controls are satisfied and shut the system down.
If the red light is on constantly (no flashing) then there is no demans being plasced on the boiler and the problem lies elsewhere. this is a very simple process of electrical tests depending on your set up (more details please).
If the red light is flashing there is a problem somewhere and the boiler has locked out.
If the green light is flashing the boiler is having a demand made of it, but it THINKS that it is at its set running temperature.
If the green light is on constant (not flashing) then the boiler is burning gas.
We seem to have 2 posts here on the same sublect. Can the moderators remove one please. Regards chrisey
so in hot water operation only say 5-7 pm at 5pm the red light comes on the timer ,should the boiler light change from red to green or not?
If all the controls are calling for heat - yes. If you would care to give us more info other than "Suprima 80" and "timer with red light" you might get a bit for info....
Control valves (type and quantity)?
Thermostats (type and location)?
Clock (make and model)?
Help us help you :!:
