Joined: 12 Aug 2007 Posts: 4 Location: Bedfordshire, United Kingdom Thanked: 0 times
Posted: Sun Aug 12, 2007 6:30 pm Post Subject:
Very confused... please help.
Hi all. We recently bought our first house and really miss having a shower I had originally planned on getting a brand new bathroom, but called Dolphin and ended up getting quoted 6-7k!
Anyway, just going to get a shower put in for the time being, but had no idea there were so many different tyes, and so much to consider.
Basically, I want the best I can get without spending more than £500. Ideally I want one with a regular controlled temperature, and the kind of power that makes me lean into it so I don't get knocked over. We have a Potterton Prima F boiler downstairs, a hot water tank in the airig cupboard, and a cold water tank in the loft I think, although I always figured it just came straight from the mains supply. I have no problem with having to remember to put the hot water on before taking a shower.
Was thinking a mixer shower with a bump to give it a kick up the bum. Is this a good idea or am I really really confused?
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Sun Aug 12, 2007 7:03 pm Post Subject:
Don't let that stop you - get a local independant to quote - a basic bathroom should not be much more than 4K unless you are going OTT...
How high is the top of the cold wate tank from the proposed shower head? a shower pump is an easy answer but you won't get much for £500. A basic bath shower mixer - £80, cheap/reasonable pump £200 PLUS VAT; cost of installation will depend on layout, but ideally you need to separate out the loo from the pumped cold supply.
Are you planning on a DIY or professional job?
__________________ Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man
Posted: Mon Aug 13, 2007 4:49 am Post Subject:
My plan, if you can call it that, was pretty much to buy a shower then pay someone to fit it. The £500 was for the goods only, I didn't expect it to include fitting.
Was looking on the MFI website and they seem to have a pretty good sale on.
Joined: 28 Jun 2005 Posts: 7496 Location: United Kingdom Thanked: 32 times
Posted: Mon Aug 13, 2007 9:14 am Post Subject:
Re: Very confused... please help.
Matt
First thing you want to price is a big new hot water cylinder to supply all that water @ fire-hose pressure/volume...possibly half your £budget
Joined: 20 May 2005 Posts: 5346 Location: St. Pierre and Miquelon Thanked: 2 times
Posted: Mon Aug 13, 2007 7:23 pm Post Subject:
Matt, you ought to give a figure including fitting and all plumbing modifications because some shower options may be cheap to buy but expensive to install, and vice versa.
For example it sounds as if you have tank fed hot water and mains cold. You could fit a venturi shower (e.g. Treviboost) without altering anything much, but it might not give the power you desire. It's possible to pump just the hot water and mix with mains cold in the shower (with modifications to cylinder connection), but it is frowned on a bit.
You might need to increase your cold storage tank capacity a lot and run a new cold supply to a powerful twin pump to get the performance you need, but this will be expensive even if the shower valve itself is quite cheap.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
