DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Reclaimed Parquet Block Cleaning
This topic originated from the How to page called Wood block / Parquet floors
Click here to return to the page called Wood block / Parquet floors.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Elgie
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 13, 2007 12:37 pm    Post Subject:
Reply with quote Thanks
I’ve recently bought some reclaimed parquet blocks to put through out my house down stairs. I have 55m2 to do, and I’m now realizing how much work I have to do !
I have found a quick way to remove the pitch from the back of the blocks using a heatgun and I’m not doing too bad cleaning the three groved edges using a sheet sander. I am struggling to clean up the remaining edge that has the tongue on. I’ve been scrapping this edge to get the majority of the stuff off and then using a mouse sander to clean it up, but its painfully slow and I have so many blocks to do…
Any advise on a quicker way to clean of the stuff that’s stuck to side of my blocks would be much appreciated !
Elgie (with sore hands ! )
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
NatalieB
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 03, 2007 2:13 pm    Post Subject:
Cleaning parquet blocks
I am about to finish the mammouth task of cleaning 25 sq m. This is how I did it after trying sanding, NitroMors and chisels. You will have found that any friction causes heat and the bitumen to become sticky and nightmarish.
My preferred method works best in winter:
Take an old hand saw (wood one) with big teeth (we cut a long saw in half). Use the teeth edge to bang the large chunks of bitumen off then use the teeth at angles to saw/scrape off excess. Take a triangular scraper and use this to clean the grooves and then brush off with a wire brush. This was the fastest method. The bitument flies all over the place so be prepared to get covered and wear gloves. This method works best in the winter (when it's cold) or if you have to do it in summer put the blocks in the freezer before cleaning.
Back to top
 Alert Moderators
topgazza
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 03, 2007 2:56 pm    Post Subject:
Thats an excellent method though.
Turpentine or Turpentine Substitute destroys bitumen but will soak into the wood if too much is used and cause staining but might be useful for those stubborn bits. Put on a cloth and wiped on it should remove light patches left after scrapping. Try it on a small off cut first to see how it fairs.
Back to top
 Alert Moderators
daviddce
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 02, 2008 4:20 pm    Post Subject:
Reclaimed parquet floor
I am considering buying some parquet that will need restoration. My idea was to run the blocks through a thicknesser to remove the bitumen, then to run through again to prepare the floor surface. Any comments would be appreciated!
Back to top
 Alert Moderators
rawtimber
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 15, 2009 11:11 am    Post Subject:
cleaning reclaimed parquet floor
The best way to clean parquet blocks is with a flap wheel placed in a spindle moulder. Carefully pass the blocks past the wheel on all four sides taking care to apply even pressure. This will clean the tougue and groove allowing you to fit with a nice tight joint.
If you wish to remove the tar the best method is to use a thickness planer. This will remove upto 90% of the tar with one pass. However it is best to clean the top surface after you have laid the flooring, to retain as much of the character as possible.
Make sure you have adequate dust extraction facilities and sharp tools and adequate PPE during either process as this will make the job safer and a more pleasurable.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Laying reclaimed wood block flooring 2 400 Tue Feb 24, 2009 5:05 pm
laying a floating block hardwood floor on underlay ? 3 880 Thu Dec 13, 2007 1:25 pm
Laying block floor techniques 9 560 Sat Sep 20, 2008 11:20 am
Block and beam floor question 4 1240 Mon Mar 09, 2009 9:06 pm
Restoring wood block floor 3 280 Wed Jul 29, 2009 9:08 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
