DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
micro bore central heating
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
johnscott
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 14, 2007 2:49 pm    Post Subject:
Reply with quote Thanks
I recently removed a radiator to decorate and upon remounting it and refilling it my central heating will not come on anymore. The boiler heats the water up in the storage tank ok, but doesn't seem to circulate hot water round the radiators. I've bleed all the radiators, do I need to bleed the pump?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
markplumb
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 14, 2007 3:18 pm    Post Subject:
yes, you should bleed the pump as running it dry will cause damage.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Tue Aug 14, 2007 6:04 pm    Post Subject:
Try turning the hw off, any bypass valve shut and all rads except the cold one off, oh and pump on full speed.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Tue Aug 14, 2007 6:11 pm    Post Subject:
If you drained system completly you may have moved some cr#p into the manifolds.
Back to top
 Alert Moderators
markplumb
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 14, 2007 6:32 pm    Post Subject:
bleed the checkvalve too if your on a gravity hot water system.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Noisy ( whining ) micro bore central heating 9 1100 Sun Aug 13, 2006 3:43 pm
Loud humming noise in micro bore central heating system 6 2540 Sun Oct 22, 2006 2:56 pm
Micro bore central heating 11 1280 Sun Mar 20, 2005 10:21 am
Problem Micro-bore central heating 3 520 Wed Jan 31, 2007 4:52 pm
fits a combi boiler on micro bore central heating system? 8 1400 Sat Nov 27, 2004 1:21 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
