DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Best Method for Sanding Parquet Floor
This topic originated from the How to page called Wood block / Parquet floors
Click here to return to the page called Wood block / Parquet floors.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
stevenbarich
from United States of America
Thanked: 0 times
PostPosted: Wed Aug 15, 2007 1:09 am    Post Subject:
Reply with quote Thanks
Hello,
I hope this isn't too much of a repeat question, but I want to sand a parquet 7-finger mosaic tile floor that consists of two old, different colored/stained tile types, as well as a newly laid section of parquet (replacement for water damaged tile).
The room is 16x32 feet. Should I use a hand-held orbital sander? Should I look around for an industrial orbital sander? I have noticed some people go it by hand, some choose a more industrial approach (i.e., belt sander, etc.). I just want to sand the tiles enough to remove any prior finishes and then apply a new stain over the entire floor, in order to bring together the three multiple colors closer (I'm not expecting miracles, but ok...).
Since there isn't a problem with leveling, just with preparing the tiles by removing the older finish/sealers, what do the wise parquet gurus recommend?
Thank you in advance,
Steve
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Wed Aug 15, 2007 10:02 am    Post Subject:
Any old finish had to come off completely otherwise you still end up with a patched floor.
Recommend proper sending with belt-sander (professional one with ongoing belt, not sheets) starting with grit 40 to get old finish off, then 80 grit which the sand-dust can be mixed with wood-filler to fill any gaps. Then grit 120 if you want to re-finish with oil or hardwaxoil, or grit 150 when you re-finish with varnish/lacquer.
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
stevenbarich
Thanked: 0 times
PostPosted: Wed Aug 15, 2007 4:01 pm    Post Subject:
Hello,
Thank you for the recommendation. I was wondering: is a belt sander the best choice for my parquet floor, which is laid with the tile grain in two directions (pattern), 90 degrees from each other? I thought that using a belt sander in this instance will leave large grain scratches on half the tile in the room.
Best,
Steve
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Thu Aug 16, 2007 9:37 am    Post Subject:
finishing with 120 (or 150) grit will prevent most of this (as long as you use a professional sander, not one which has a metal bar that holds the sheet of sanding paper together, that might leave loads of marks).
Go horizontal first, then with same grit vertical. Repeat with other grits.
__________________
Back to top
 Alert Moderators
Great-Uncle-Bulgaria
from Bulgaria
Thanked: 0 times
PostPosted: Sat May 17, 2008 7:35 am    Post Subject:
You're not wrong about those belt sanders!
Hi WoodYouLike. I have recently used a HireTech HT8 belt sander (with the clamp bar). When you say it could leave loads of marks, does it look something like stripes? I have stripes that look almost like the effect you'd get from light streaming in through louvred blinds, although the floor appears completely level. icon_eek.gif In your opinion, what would be the best way to remove these marks? I have tried wire wool, but it's real hard work, and doesn't seem to make much of an impact. Do I need to sand again with an orbital sander? Time is real tight. Thanks in advance for any advice you can offer.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Tue May 20, 2008 8:09 am    Post Subject:
The HT8 is a drum sander, not a belt sander.
Best result to remove the shatter marks you have now is to hire a belt sander and sand with grit 80, followed with grit 120
__________________
Back to top
 Alert Moderators
flutterbye
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 09, 2009 4:01 pm    Post Subject:
Hi
Would a Trio Sander be just as good?
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Fri Jul 10, 2009 8:37 am    Post Subject:
For the final sanding, yes. For a first and second sanding on unfinished floors or to remove all of the shatter marks, no.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Best Method for laying porcelain tiles on concrete floor? 2 5120 Mon Sep 13, 2004 7:26 pm
Which method to lay floor ? 9 420 Wed Jun 10, 2009 9:52 pm
Method of laying tiles in bathroom? 5 1060 Fri Jun 30, 2006 10:13 pm
Best method for cleaning & renovating vinyl flooring? 3 920 Wed Mar 14, 2007 12:25 pm
Best install method for Oak Floorboards 6 440 Fri Oct 09, 2009 1:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
