DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
replacing 3 gang, 2 way switch,
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
Paulus1902
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 15, 2007 7:52 am    Post Subject:
Reply with quote Thanks
I thought this would be simple but it\\\'s not.
I\\\'m replacing the hall 3 gang switch which operates an outside light, the hall light and the landing light. The landing light can also be operated by a switch on the landing.
The existing switch has 5 terminals across the top.
Blue wires go to each of two terminals marked 1W. Yellow wires go to terminals 2W and com. The final terminal has no wire to it.
There are 4 terminals across the bottom. A red wire goes to com, another red wire to 1W which is then connected to a second com terminal. The 4th terminal has no wires.
The new switch has terminals as shown below:-
com L2 L1 com L2
L1 L2 com L1
I have tried to associate the new switch terminals to the old ones but can\\\'t get all lights working. In particular I can\\\'t get the landing light to work from both hallway and landing switches.
Sorry this seems a long question but I thought the more info. the better you would understand. icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Wed Aug 15, 2007 8:11 am    Post Subject:
The terminals in both switches are grouped in sets of three.
On the old switch they are called COM 1W and 2W
On the new switch they are called COM L1 and L2
If you look at the back of each switch there should be lines on the back to indicate which sets go together
Assuming you made a note of which wires went where it should be a straight one for one change over.
PS, you've posted this twice, can u delete one of them?
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
Paulus1902
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 15, 2007 9:33 am    Post Subject:
Thanks, I didn't realise the terminals were in sets of three for each switch.
Sorry I'm new to DIYnot and can't find a way to delete the repeated question.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Replacing a 2 gang 2 way switch 6 580 Mon Mar 01, 2004 1:51 pm
Help! replacing one way switch with double gang two way 2 640 Wed Mar 09, 2005 12:00 pm
Replacing 1 gang switch with 2 gang - now other rooms broke! 11 340 Sat Oct 24, 2009 10:51 am
Replacing a 2 gang dimmer switch 4 2420 Thu Apr 07, 2005 11:15 am
Replacing 6 Gang Light Switch -Crabtree to MK 15 1840 Sat Jan 20, 2007 1:43 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
