DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Insulation between rafters
This topic originated from the How to page called Loft Insulation
Click here to return to the page called Loft Insulation.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
aswadeem
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 15, 2007 9:33 am    Post Subject:
Reply with quote Thanks
I have been informed by the building inspector that the rafter insulation must achieve a U value of 0.2., therefore I must use 145 mm Kinspan which I think is a bit excessive. However, to comply with existing building regs are their any other products that achive the u value stated above, and that are considerably thinner, because I dont really want to lose any head space due to using the kingspan product. Also, the building control officer also stated that I must cross batten the kingspan, which I am not quite sure what he meant. Although I have manage to drop the ceiling and put new beams in, and fitted the stairs, I am at another hurdle in which I require some clarity.
Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
freddymercurystwin
from United Kingdom
Thanked: 41 times
PostPosted: Wed Aug 15, 2007 12:10 pm    Post Subject:
You cant get much better than kingspan so I'd think not, some people's local authorities allow tri-iso in addition to a single layer of kingspan but your BC officer sounds like a stickler so that's prob not an option. Cross batten the kingspan just means if the first layer runs parallel with the rafters the second layer should run at 90degrees to the first layer, its to minimise draughts. Joints should be taped as well.
Back to top
 Alert Moderators
aswadeem
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 16, 2007 1:31 pm    Post Subject:
insulation beneath rafters
Thanks for that valuable info. However, does that mean that I must use to layers of kingspan that makes up the 145 mm thickness. ie 80mm kingspan in between the rafter and 65mm kingspan cross batten.
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 41 times
PostPosted: Thu Aug 16, 2007 6:10 pm    Post Subject:
Yes, provided you leave your 50mm airspace under the felt.
Back to top
 Alert Moderators
aswadeem
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 17, 2007 9:03 am    Post Subject:
Concerning the 50 mm air space, doe this still applies when you have breathable felt, because I mentioned this to the building inspector, and he responded that I can place the kingspan close up to the felt, due to the fact I have used breathable felt, as long as their was a bit of slack on the breathable felt which is fixed on the rafters, is this correct otherwise I will ring the building office before I commence work.
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 41 times
PostPosted: Fri Aug 17, 2007 9:27 am    Post Subject:
If you’re using a breathable membrane that is correct. Any moisture that gets through the insulation can escape through the membrane rather than being drawn out through the airgap.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Between Rafters insulation questions??? please help 3 560 Thu Apr 23, 2009 1:15 pm
Insulation of 130mm between rafters...is that right? 3 620 Fri May 01, 2009 4:19 pm
insulation between rafters 2 620 Mon Feb 02, 2009 9:01 pm
Insulation in rafters 2 160 Tue Oct 06, 2009 8:10 am
Insulate Rafters 4 1560 Wed Sep 26, 2007 1:28 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
