Joined: 26 May 2004 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Wed May 26, 2004 10:55 am Post Subject:
wiring a continental 2 pin plug
Anyone got any ideas on how to wire a continental 2 pin plug, the earth goes to the centre of the plug but there is no designation for earth and live and i'm confused!!
Thanks!
Joined: 26 Nov 2003 Posts: 750 Location: Dorset, United Kingdom Thanked: 0 times
Posted: Wed May 26, 2004 11:27 am Post Subject:
Apparently, (but don't take my word for it) the continentals use double pole switching so they're not fussed as to which is live and which is neutral. This can lead to outlets being wired up either way.
- I assume you mean live and neutral here not earth and live as you have worked out that the earth is the centre pin.
The UK always switches the live side so if you're connecting a switchable appliance you need to know which side is which.
I think the only way to know for certain is to test the outlet socket you're going to use. I believe you can by plug in testers for this.
__________________ Never assume tomorrow will get better
Joined: 08 Apr 2004 Posts: 386 Location: United Kingdom Thanked: 0 times
Posted: Wed May 26, 2004 12:36 pm Post Subject:
First of all, if it has an earth connection it is not the 'continental' europlug. Could you be referring instead to a German Schuko plug? :
The French ones are polarised by the earthing hole in the plug, but there are also designs which are compatiable with both France and Germany, which may or not be polarized, as a German outlet is nonpolarizing and a French outlet polarizing.
Anyway, I'll get down to the main point:
If it's a schuko plug and doesn't have markings for live and neutral, then it doesn't matter which you connect to which pin, so long as you connect the safety earth to the correct pin.
True, but most appliances are designed for use across the whole of Europe nowadays.
One final point: This should have been posted in the Electrics outside the UK section.
P.S. While searching for an image, I found something very curious... A schuko outlet which claimed to have a BS EN number... Why?
Posted: Wed May 26, 2004 5:53 pm Post Subject:
I see. I've only been to Germany once before, and the house we stayed in had all of the sockets earthed. I noticed that all of their powerstrips are earthed, but their cluster adaptors fit into the schuko recess, and themselves were shaped to only allow two pin europlugs.
I thought then that a two pin socket would be recessed if the cluster adaptors were anything to go by.
Posted: Wed May 26, 2004 7:11 pm Post Subject:
True... and you can plug an earthed France-only schuko plug into a german socket.
Also, worryingly europlugs and schuko plugs can be plugged into shaver sockets. I wonder how many people are watching the telly at the end of their bath, thanks to a travel adaptor right at this moment...
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Wed May 26, 2004 7:16 pm Post Subject:
just how much do tvs draw?
shaver sockets are only rated at 20W (though i do remember a friedn of mine (known here as london spark) said he plugges a 60w hexagon pod (you know those 3 channel hexaganal pods in which one contains a sound to light unti and the pods connect to the controller through europlugs) into a shave socket and it worked
yes we were both much younger and more reckless then
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
