DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
My First Shower Fitting
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
welsh_gje
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 19, 2007 8:33 pm    Post Subject:
Reply with quote Thanks
When we purchased our house back in \\\'98 there was an electric shower fitted, supplied by one cold water pipe. Everything was good. We replaced the shower (because it was old), fitted our new base and glass enclosure - it has worked ever since.
Now the Gainsborough shower we have fitted has decided to pack in. It doesn\\\'t heat and one assumes that the heating element has packed in (even though there is heat sometimes).
So, the missus has asked me to fit a power shower. In starting my research, I came across this forum.
Fitting the new enclosure that she wants and the new base isn\\\'t a problem. SUssing out the pump and it\\\'s requirements are not a problem. Re-routing the cold water pipe isn\\\'t a problem - it is already coming from the cold water storage cistern.
My question is simple - where do I take the hotwater feed from into the pump? Coming out of the pump to the shower I\\\'m assuming is one pipe to the mixer. Also where is the best place to fit the pump? My B&Q book tells me I take it from the top of the hot water cistern - fitting a splitter connection. If this is the case and anyone here agrees then thanks and I\\\'ll let you know how this newbie goes on.
Many thanks in advance,
Gareth Edmondson
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Sun Aug 19, 2007 8:47 pm    Post Subject:
What does \\\ mean?
Where else would you consider taking the hot water from?
Tony
Back to top
 Alert Moderators
welsh_gje
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 19, 2007 9:28 pm    Post Subject:
Agile wrote:
What does \\\ mean?
Tony
\\\ = sorry that was a typo.
Where else? I don't know - but I assume the top if the correct place then LOL.
Thanks for the reply,
GJE
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sun Aug 19, 2007 10:12 pm    Post Subject:
Agile wrote:
What does \\\ mean?
It means that you're being obtuse and pompous.
The side, using an Essex flange - the vastly superior option. icon_rolleyes.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Mixer shower fitting 2 540 Sat Jan 27, 2007 3:48 pm
replacing cold water tank/fitting shower pump 13 620 Thu Apr 05, 2007 1:33 pm
Trevi therm shower fitting question 4 340 Tue Apr 17, 2007 5:44 pm
fitting a shower tray 5 740 Sat Apr 21, 2007 12:03 pm
Fitting new shower base. 3 1600 Tue Jan 02, 2007 11:03 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
