B bennychen Joined 20 Aug 2007 Messages 2 Reaction score 0 Country 20 Aug 2007 #1 Hello..if the neutral wire is not working..what should i do? those wire is covered in the wall.. Can i just join the neutral wire to live? btw I am trying to install a fluorescent light.. Thanks!
S Softus Joined 21 Oct 2004 Messages 19,508 Reaction score 29 Country 20 Aug 2007 #2 bennychen said: Hello..if the neutral wire is not working..what should i do? Click to expand... Please explain a bit more about what's wrong with it. those wire is covered in the wall. Click to expand... Yes I see. Can i just join the neutral wire to live? Click to expand... No!
B bennychen Joined 20 Aug 2007 Messages 2 Reaction score 0 Country 20 Aug 2007 #3 Hi, thanks for reply. ok i think the neutral has been cut off..those wire are all cover inside the wall..so i can't reconnect it back..
S Softus Joined 21 Oct 2004 Messages 19,508 Reaction score 29 Country 20 Aug 2007 #4 Thank f*** that you're not in the UK then.
JohnD Joined 15 Nov 2005 Messages 97,350 Reaction score 8,391 Location South Country 20 Aug 2007 #5 cut the wall open to find the wire. Or run a new one. I think you need to get an electrician in to help you as you do not seem to know what you are doing.
